spoke's Avatar
Originally Posted by Aurel View Post
Now is time for an update. I finally figured out what was preventing sparks, and now have ignition again.
I checked again the voltage at the CDI box, and even without cranking, it was only 6.5-7V.
The voltage at the front fuses was a solid 13V, and the voltage at the engine fuses was only 6.5-7V.
I checked my ground connection but that was fine.
I opened the 14 pin connector, and sure enough there was a connection holding by a thread that broke immediately. I resoldered it and voila, my ignition is back.
Fantastic that you got your 911 running again. Good detective work. Connections can cause all kinds of strange issues and lead to dead ends when testing components.
I'm puzzled by one thing though. You say you measured voltage at the CDI box was 6.5-7V. But previously you mentioned the voltage at the CDI to be 13.1V. Were these the same measurements at the same place on the CDI?
Find Spoke's LED Products:
www.spokeworksled.com
Old 06-01-2025, 06:50 PM
Free minder
Aurel's Avatar
Yes, that is what misled me too. I did see the correct voltage at the fuse that feeds the CDI box, then two weeks later it was half that. I think a very lose contact inside the 14 pin connector may have caused this.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 06-02-2025, 03:02 AM
PCA Member since 1988
I've seen frayed wires at the 14 pin connector too. There must be enough vibration and movement of the engine harness to cause those connections to fatigue and break. I will guess that several other of your connectors are hanging by a few strands too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2025, 08:53 PM
Free minder
Aurel's Avatar
Here is another update: the car starts right away and I got the idle set and stable at 950 rpm, all good…but the advance I am reading with my strobe light is the maximum mark I have on the pulley, which was 35 degrees BTDC. Also, if I give it a little gas, it backfires in the exhaust and cannot pick up much rpms.
Is it possible that my distributor is one gear tooth off? Would one tooth cause the advance to shift by 35 degrees? If that is the case, it will be an easy fix.
Old 06-19-2025, 12:22 PM
Typically occurs when the green wire connection is reversed.
Dave
Old 06-19-2025, 01:55 PM
Free minder
Aurel's Avatar
Ok, if that is the case it will be an easy fix too, since I made connector spade quick connects to change those polarities. I will try it!
Old 06-19-2025, 02:35 PM
Free minder
Aurel's Avatar
YESS! I just switched the wires, and she is now screaming like never before!
Thank you so much, Dave. You saved me from pulling the distributor one more time and get nowhere…
Old 06-19-2025, 02:54 PM
LJ851's Avatar
Thank you so much mysocal911, you saved me from pulling the distributor one more time and get nowhere…
Switching the wires does more than change the timing, it throws off the rotor phasing to the cap which is why it runs so poorly in addition to the timing change.
Old 06-19-2025, 02:57 PM
Free minder
Aurel's Avatar
The part that threw me off is that I checked the signal from the green wire going to the cdi box with the oscilloscope and it looked correct. But obviously, I can tell now that the wires are switched, I was wrong.
Old 06-19-2025, 03:06 PM
