This thread is full of such positivity. I love it!
Oil change will will allow the following:
Crawl under your car and check (snap some pics to share) the transaxle bushings. As others have said, those are super easy to change. Then head to the back and check the motor mount bushings (same bushing as the transaxle). Also super easy to replace. Do not get caught up in the buying poly super stiff or solid mount bushings. Just get stock rubber replacements for both (4 in total). Once you've driven the car in anger enough times, you can determine if you need stiffer mounts. If shifting is a challenge, buy the coupler and replace that as well. The $3-500 you'll spend on another PPI should cover the cost of everything above. You'll know for sure if you need a top-end rebuild (broken studs) and start the journey of getting to know your car and more importantly how to fix your car. All of the above is less than a day's effort. As others have said, get a manual (I might have an extra), get Wayne's 101 Projects book and lean on this forum and local Pelicans. Harry, Pete and I are local enough to you, along with a bunch of others. I had about 15 locals helping me trouble shoot my DME. We're a pretty good group of gear heads. Introduce yourself over on the local thread: https://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/500446-oregon-pdx-beers-burgers-second-thursday-every-month.html
Josh 85 M491 Coupe - "Fat Bastard" |
gearhead
Send me a pm with your name and address. I’ll send you these manuals for the price of postage. I have all the factory manuals for myself and these books just sit around not being used.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
And drive it and re asses over the winter.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Good stuff you two. Erik
1986 911 Coupe 1986 911 Targa |
1984 911 Targa 1980 Toyota Pickup |
Johnny, The Bentley Manual (next best thing to the factory manuals) would be an excellent addition to your library as well.
Still here
![]() Yes, get the Bentley from our host, the best reference other than factory manuals. While you're at it, buy some oil, both engine and tranny, filters, washers etc. Spare fuel pump relay, I probably forgot something. We haven't gotten to oil selection yet ! Last edited by pmax; 08-06-2025 at 12:44 PM.. |
Oh no... I hope there's not a limit on number of forum pages here...
FWIW.
If his motor issue is JUST a bad copper cylinder base gasket and head studs. Johnny may be able to get away with removing the motor, Taking the heads and cylinders off, clean up the cylinders, replace any bad studs, and put it back together. He may or may not need to get a valve job as well.
https://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html FWIW, the current EZ answer is Valvoline VR1 20W50 and Mobil 1 5W-50. The LiquiMoly oils at Halsey are a strong third.
Rothsport if you can get in. A&P otherwise, which I use. Rationale I'll PM only. HarryD has some private guru that he won't share with us in the PNW.
First clean and tighten ALL the grounds on the car and learn where they are and replace any that are not perfect.
Fast, easy, cheap, this will be a step ahead of 90% of the people on this site and make the car start better and many problems will go away.
I'm not picking my nose..I'm porting my upper intake manifold. |
I know HarryD's secret, but can't share for fear of losing the ability to call in the calvary when needed
Sounds like you have some great advice and that you are plenty capable of doing most of the needed work.
I will add that the transmission and motor mounts are not only easy to do, but may also be contributing to bad shifting.
Rutager West 1977 911S Targa Chocolate Brown |
Audi & Porsche AKA A&P is still there on 82nd. Al still owns the shop which is where my motor is sitting. Not his fault, the MFI pump is out for a rebuild.
Myamoto, someone in your town just got a 912E. He posted over on 912BBS. Last edited by nickelplated5s; 08-06-2025 at 03:41 PM.. |
I'll have to see if I can figure out who the new kid in town is. Or maybe it's just and old kid with a new toy!
Good lord that’s a beautiful 912. I saw a similar one in yellow a month or two ago at John’s Marketplace here in town. I wonder if it was the Avant Garde guys making rounds or if it was another local one.
