I did the full fuel line replacement on my 911 and the ledge of the pit was a comfortable place to sit to get to the firewall and disconnect the old fuel lines. And wiggle the new lines back through. All with the engine and transmission in place.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
BendPak 2 post lift for 11' ceiling
I have a BendPak lift in my garage with 11' ceilings. You can raise a 911 to full height without any issues. Look for the floor plate models.
5" concrete with # 4 rebar 18" OC is plenty. The connection to the floor is the weak link. The bolts will tearout before the concrete fails in compression. Bendpak provides expansion anchors. I would use Simpson set-pac epoxy. It is way stronger. Mcmaster carr sets insert that you can bond into the concrete. If you do it this way, you can bolt it down. If you ever need to move it, you are left with tapped holes in the concrete. My Cayenne fits under the car if I remove the front wheels. |
Lash
I have a 28X56 foot garage and 14 foot high. I went with the Challenger 10,000 lb two post lift. For me a four post lift would take up to much room. As others have mentioned purchasing a lift is worth every penny.
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
Been here a while
If I had to do it again, I’d just do it sooner. Can’t imagine my shop without the lift.
2 post lift I bought from a Saab dealer that was shutting down in 2003 when we bought our house. Installed a few weeks later when we transacted from the house to the barn to install power, gas and water. Never looked back.
looking for 1972 911t motor XR584, S/N 6121622 |
Here is my '71 914-6 on our freshly installed BendPak mid-rise scissor lift. I had the same set-up in my last garage. This garage is 1600 sq. ft. with a 12' 6" ceiling. The garage is not finished yet, but getting close. Ramps are flush to the floor when down, hydraulics run in a chase in the ground and the control panel is mounted on a tall cabinet over the bench.
'71 914-6 #0372 '17 Macan GTS Last edited by Cairo94507; 09-09-2025 at 06:21 AM.. |
Currently building my Garage,
They poured footings today ![]() ![]() ![]() will probably put a full rise Scissor lift in the left bay. I have a 4 post that will go in the right bay for storage that came from my old house. ![]() ![]() Similar to above Last edited by Brickwhite; 09-08-2025 at 09:15 AM.. |
I went with MaxJax. Works very well and when not needed, unbolt the posts and roll everything into a corner. The posts have wheels and handles at the top to assist moving them.
Maximum height is about 4 feet which is good enough for everything I need.
Find Spoke's LED Products: www.spokeworksled.com |
How much work is it to unbolt the MaxJax? Or perhaps a better question might be: what do you have to torque the bolts to each time?
I have a HF dolly to store the 4 arms. They are heavy as sin. The posts roll very easily and easy put in place. The only preparation for the garage (besides placement) is drilling the holes. Documentation is good and thorough. Tech support is good. Drilling ten 7/8 inch holes was a pain. Had a medium sized hammer/drill but it died half way through the 10 holes. Bought a heavy duty Bosch hammer/drill and it went through the concrete like butter. They provide screw on caps to protect the holes from debris when not in use.
That's cool that they give you cover caps for the holes. |
The only issue I've had so far is the one coupling is leaking. That coupling will need to be replaced. Tech support says they should be lubricated but not sure how to do that. I've disassembled/reassembled about 20 times already. My wife didn't like the post being up in her spot when not in use. My side had a dead soldier ('86 930) so didn't make sense to put it on my side.
PCA Member since 1988
Blucille has the best advice: “If I had to do it again, I’d just do it sooner.”
Any lift is better than sliding around on your back or belly under the car with dirt and crap falling in your face.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
