vacuum leak test on 1980 911sc?
Hi all,
I did a vacuum leak test and found a lot of smoke comming out from the fan. Please tell me what the leak is that? See pics below. ![]() ![]() Thanks. Khuong |
PCA Member since 1988
Loose or compromised gaskets between the intake manifold and the heads usually cause smoke to come out of the fan. The smoke around the airbox-to-intake runners may be a cracked airbox.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thank you.
