sport seat restoration question
I am looking to strip down my 1972 recaro sport seats reclining mechanisms in order to restore. I have searched the forums but only find information on the comfort seat mechanisms. Can anybody offer advice on how to dissemble and restore these sport seat mechanisms?
Many thanks and Happy Thanksgiving
Old 11-27-2025, 08:56 AM
https://youtu.be/--YyzE7vfV8?si=bQScIKM_BdKqN7sl
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 11-27-2025, 09:56 AM
thanks for your quick response - I had seen this video from Mike's Restorations, great information for the Recaro comfort seat, but I was trying to get something specifically on the sport seat mechanism
Old 11-27-2025, 10:48 AM
for mine
I removed the springs and blasted them because they were in mediocre shape. but not quite as bad as yours.
Once they were apart i re applied the texture via a worth stoneguard. took a bit of trial and error to replicate the texture.
Then I built a tool to re install the spring.
Where are you located?
1976 914
1986 951
Old 11-27-2025, 08:47 PM
Originally Posted by colingreene View Post
for mine
Thanks for your information - I am located in Chapel Hill, NC
Old 11-28-2025, 04:02 AM
I could potentially build you a tool if you want.
the springs are pretty agressive. Ill see if i have other pictures of doing the restoration.
1976 914
1986 951
Old 11-28-2025, 10:09 PM
Any information and/or pics that you have would be gratefully accepted - not too much detail available on stripping and rebuilding these items - thanks again for any help
Old 11-29-2025, 02:50 PM
PCA Member since 1988
After I sandblasted my hinges, I used a spray can of truck bed liner to repaint them. It's holding up well and looks pretty close to the original spatter finish.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-30-2025, 02:20 PM
Thanks for the advice - I will looking into that as a solution
Old 11-30-2025, 02:41 PM
Most people use VHT wrinkle coat rattle can paint, but technically, it's a spatter finish like Pete says...
Old 12-01-2025, 12:39 PM
Thanks - I will check it out as my hinge mechanisms are going to need completely refinishing
Old 12-01-2025, 04:48 PM
Looks like pretty light rust. I would recommend picking up a gallon or two of Evapo-rust or what ever similar brand is locally available. Stuff really works and then you don't have to disassemble.
I used to glass bead all that stuff and found the rust remover chemicals work better and don't change the surface of the metal.
Old 12-01-2025, 05:55 PM
I can get that locally. I will buy a gallon and try it out - thanks for the tip
Old 12-02-2025, 07:56 AM
Quick update and thanks to all that have posted. With plenty of penetrating oil and some gentle persuasion, I split the most corroded of my reclining mechanisms. See attached.
I have now to decide whether this mech is too far gone to restore - but also have to bear in mind that these are fairly rare to replace - comments and suggestions are always welcome :-)
Old 12-06-2025, 08:50 AM
That was submerged in water for a long time, probably salt water. Possible salvage from a flood car. Where did you get the seat? if the hinges are like that the internal frame is probably toast too.
Old 12-06-2025, 02:45 PM
Seat frame is okay - some rust to replace - I think the mechanism sat on dirt for a long period - note only the bottom portion of the mechanism is badly corroded
Old 12-06-2025, 03:06 PM
