-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Which alternator for 1972T (http://forums.pelicanparts.com/showthread.php?t=1183287)
kwikt 911 09-02-2025 05:18 AM
I'm planning on replacing my original marchel alternator on my 72 911. Which one is direct replacement using original external regulator and direct wiring plug and play.
HarryD 09-02-2025 06:49 AM
If you are interested, I have an internally regulated alternator from my 1973 which should work for you.
tobluforu 09-02-2025 07:11 AM
Why, is your old one kapoot? If it's on its last leg, check around your area as there might be a shop nearby that will rebuild it. Or Harry will hook you up.
Rosco_NZ 09-03-2025 01:28 AM
Some are of the opinion the early system with the seperate voltage regulator is better, as it’s not exposed to heat and breakdown. I rebuilt mine (bearings and new carbon bushes) and had the regulator tuned (they drift up & could boil your battery). I’d suggest keeping original if possible.
kwikt 911 09-03-2025 05:03 AM
Yes that's my intention to keep it OE since it lasted this long. I owned this car since 1985!
30westrob 09-03-2025 12:15 PM
I have always had great success with a local auto electric shop. Usually Bearings, brushes, and diodes, all cheap, and you are ready for an other 50 years. Take your VR with you a they can often check it out. Rob
