-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   What Size/ Fitting is this 75 CIS Fuel Return Line (http://forums.pelicanparts.com/showthread.php?t=1183896)
Louisieg55 09-18-2025 07:57 AM
http://forums.pelicanparts.com/uploa...1758207258.jpg
I’m working on figuring out the correct fitting for the return line.
It’s the solid hardline that transitions from soft hose to hard line.
So far I’ve tried a 6AN flare to 6AN ORB male O-ring adapter, as well as 6AN to 14mm, but nothing fits. It looks like some kind of compression fitting, but I can’t pin down the size. Ultimately, I need to adapt it to 6AN.
The odd part is that on the return line I used when pulling the new 6AN hoses, the factory male connection spun onto the 6AN line fairly easily — not a seal, but enough to pull the line through.
boyt911sc 09-18-2025 02:01 PM
Return Fuel Line Fitting………
Louis,
The return line fitting in your picture is a 14-mm x 1.5 compression fitting.
Tony
Louisieg55 09-18-2025 03:39 PM
Thanks Tony, Ill updated on my main build/trouble shooting thread.
But I got the front pump mount/tunnel lines run (That was fun :) and now just need to complete the rear.
THanks
L
