Registered Minimalist
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Over a few years I have studied the books of Probst also "How to tune & modify Bosch Fuel Injection" by Ben Watson and "Bosch CIS" by James Weber. After checking fuel pressures and a couple cursory items there is not much available for the basic garage hack. Also, I have years of experience with carbs |
I think the real long term issue with CIS is that the parts will become harder to find and more expensive to replace. There are only a handful of shops or people left who still rebuild WURs and fuel distributors. Once those experts retire or stop doing the work, people like myself will eventually have to convert to carbs or fuel injection just to keep these cars on the road. Even if you have the skills and knowledge, the parts simply will not be available at an economical scale.
Tony mentioned it took him close to five attempts to get my fuel distributor dialed in correctly using different shim combinations. That tells you how precise and specialized the work is. And that level of expertise is getting rare. Carbs are heading in the same direction. It is becoming harder to find people who know how to rebuild them well, and locating quality parts is not getting any easier either. In another five years I think modern fuel injection will end up being the most common option for people looking to upgrade or simply keep their cars running reliably. Just my two cents based on research, talking with people, and trying to diagnose what was going on with my own car. |
Good post.
Thanks, I am lucky to have a solid unrusty example, came from the Southwest and hasn't been driven in several years due to the faulty CIS. Engine was rebuilt 6 years ago, but engine builder didn't have the tech to resolve the CIS. I am really looking forward to getting some seat time with this beauty next season.
Still here
Anyone of those "specialists" will have no trouble with CIS either. ![]() ![]() In fact, Bosch itself offers a remanufacturing and repair service ![]() That probably ensures these will outlast those carbs and "modern" EFI systems as well. Quote:
I'm guessing ... and it's a pure guess ... Porsche didn't get around to a good KJetronic system until the SC era. I speculate wildly it may have something to do with the seemingly convoluted intake system unique to CIS. Quote:
When the engine doesn't even fire up, how would that technique work ? Last edited by pmax; 11-16-2025 at 03:38 PM.. |
Now my Alfa on the other had with it's twin Dellortos. Well, starting it is like trying to wake up a surly teenager. Once you're running it's ok - until it stalls at a junction - or idles at 2000 RPM, or spits flames in your face. It does make a great sound though!
www.classicretrofit.com |
Full Send Society
I dunno, with the ubiquity of cad, 3D printing, cost-effective rapid machining, etc… it seems like just about anything can be made for relatively cheap.
Need a specialized fitting: make 10 of them and sell the others to CIS folks here and make a small profit… I think the real issue is being intimidated and overwhelmed…. There’s no mystery of how CIS works, plenty of books and documentation… not sure why the fear…
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
I have to put my $.02 in since you might see that I have a stupid long stream of posts on this site trying to fix my CIS. Lots of great people on this very thread helped me out. Sadly, perhaps the biggest problem was caused by my mechanic who swapped out my original fuel distributor for a late version (006) and I didn't realize it as I kept chasing down problems. Once I finally found that and got the correct one back in, it's all great again. I'm so glad I kept at it.
I've driven lots of other 911s, including carb'ed 911Ts of all engine sizes. Personally, I think my car has better power and throttle response. Carb'ed engines with their butterflies opening all at once can increase sound more quickly. I think that is what leads people to think they are getting faster throttle response. |
Books and documents are great as far as they go. Going to drop my engine, again, and try and sort things out one last time. If it’s not right by next summer, my CIS will be on the Pelican Marketplace. A guy can only take so much. |
going thru the same process. ITB EFI. waiting for ecu and wiring...
79 911sc 3.2 |
All that and the lack of mechanics/equipment who can diagnose this 1/2 century old stuff. Still wished I would have done this years ago Thanks to all posters, hit a soft spot |
1980 911SC Targa 1990 S2 Cabrio (sold) 2004 C4S (sold) 2006 Boxster (sold) |
Full Send Society
Going from CIS to modern EFI is a no-brainer.
Going form 50+ year old tech to 50+ year old tech seems silly if reliability and ease of use are key. If the experience of carbs is desired, then rock on with your bad self, but if eschewing the finicky qualities and NLA aspect of CIS are the goal, then the answer must be EFI.
Full Send Society
I posted this a while ago but froma quick search, the pricing is accurate-ish:
RHD ITBs are $2300 MS3Pro mini is $599 Wiring harness is $75 14.7 O2 controller with Bosch sensor is $135 Fuse panel is $15 Oil temp sensor is $20 TPS sensor is $50 Allow $100 for hoses, etc... Allow $100 for wiring accessories, etc... If you want to use Deutsch connectors, you can add $100-200 depending on what you get and how many you use... You'll need tools but we don't count toys, er, tools as they are not project specific and will find use elsewhere. There you go. About $3400 or so. Add MSD street fire ($175) and pertronix ($130) if you want to get rid of the CDI and points. Or if you want to delete the dizzy all together you can go wasted COP for about $200 more. (Audi 1.8 coils are about $20 each) For under $4k you can build a very nice EFI/ITB wasted COP, sequential fuel system. Surely you can spend $10-20k on another system and we can debate till the cows come home about the differences, but if you're not racing, the returns diminish pretty quickly.
Regards, Guenter 73.5 911T, mod |
I must be really old, still like points and carbs and have a point file in every one of my vintage machines
also still on the fence with a "smartphone", why do we need this tech anyways |
