3.2 Smoke…
My 3.2 with 156k on the clock started to smoke recently.
https://youtu.be/eGOJauaNRr4?si=tyVuhuOq5QN0eQ8a
I think I know where this is going, but figured I’d tap into the brain trust.
Leakdown was completed about 4K miles ago and looked good. Valves were adjusted at the same time.
Mostly stock car with SW chip and M&K M32 pre-muffler and M33 muffler added within the last 1,000 miles.
Budget is “do it right, do it once”. I’m not treating this as a preservation car that needs to stay stock and/or be fully reversible to stock. I wouldn’t mind a little more power, but it doesn’t need to be a monster.
With help, I did the clutch and all the “while you’re in there” parts a few years ago, but time is super tight now (kids in sports, career at fever pitch). I want the car back on the road when the first gully washer clears the salt in March/April. Some DIY is an option but it’s time constrained.
Complicating matters, St. Louis doesn’t have a particularly reliable Indy shop scene at the moment. The tech at the Porsche dealer is fantastic, but at dealer labor rates, and they don’t really like deviating from Porsche-factory parts/specs.
I’ve searched and read the threads and am looking to ensure that I’m thinking through the correct next steps and options before proceeding.
-Mike
-Mike
1987 911 Carrera Coupe
Old 11-23-2025, 08:33 AM
Has it being sitting for an extended period, several weeks/months?
Did you drive for +30 minutes/10 miles to get engine temperature and if so is that smoking from after a long drive or just a driveway start up? Periodic short start up and shut down won’t do much to burn off condensate.
In your video, the smoke doesn’t appear as a heavy oil billow and seems to dissipate quick.
Does it smell of engine oil or gasoline (leaky injector) ?
Could simply be condensation in either the gasoline or the oil (from sitting), not seeing much in the way of the tailpipe dripping water like on cold mornings which can exaggerate the visuals of some bad gas or contamination in the oil.
Commonly, worn valve guides will allow some oil seepage (over time from sitting) into the cylinder(s) and this sort of event usually burns off after 5 minutes or so after start up and idling, assuming the oil level was never overfilled.
For what it worth, driving for 30 minute jaunt in winter isn’t a bad idea provided not salt or brine laden puddles are on the road, it allows any oil condensation that naturally occurs in ambient temp swings to burn off.
Old 11-23-2025, 11:47 AM
Car is driven regularly.
Yesterday’s drive was 15 minutes each direction with a 20-30 minute stop in the middle.
It doesn’t smoke like that at cold start.
Injectors are new.
Smoke is white with maybe some blue. Does not smell of gas.
A few more videos that may help:
https://youtu.be/daD9M1vtlNI?si=7hOqXQ3bT1O1Qx-A
https://youtu.be/rj1ZfU756_k?si=hv-q0FhoAqlDUXgc
-Mike
Old 11-23-2025, 12:31 PM
Send a message via Skype™ to kyngfish
Mine at 100k miles never smoked on startup or decel. But it started smoking when I would stop at stoplights and idle. Leakdown showed percentages all in the 90s. But a leakdown doesnt show if it needs a valve job. What it DID do was burn through a quart of oil in about 400-500 miles.
It needed a top end. Now it smokes on startup. But I burn a quart of oil in maybe 1300-1500 miles.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 11-23-2025, 09:05 PM
proporsche's Avatar
Injectors are new.
Driving 15 minutes is absolutelly not enough to get the engine warn at all.Also when was the last time you had service done? Engine is kinda noise.
Were the valve giudes ever done on this engine,? With 156K more likely that is what you need..on 87 i have done several engine valve giudes at even 30k miles( 87 had problem with them)..i`m sure your is overdue.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-24-2025, 12:41 AM
This is very similar to my situation. Often at stoplights I’ll get the cloud of smoke blowing by,
-Mike
Old 11-24-2025, 05:41 AM
Ivan
October 2023 the valves were adjusted and new injectors installed. About 4K miles ago.
Valve guides have not been done. Valve guides seems to be where this is headed.
-Mike
Old 11-24-2025, 05:44 AM
proporsche's Avatar
ok still there is a lot of noise from your valves...if it was done right?
The noise could also be the valve guides
here is how your engine should sound...
cold
https://www.youtube.com/watch?v=Out_PKGkYYY
and here since somebody asked warm engine after i got home from 2 hour driving
https://www.youtube.com/watch?v=EUMbXSvZUNI
you can hear the difference
Ivan
Old 11-24-2025, 07:26 AM
If valves guides are severely worn, it can be difficult to set the correct gap on the valves, which is posibly why the engine sounds a bit more noisy than expected.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-24-2025, 07:37 AM
I was told that the reason for this is that at idle is when vacuum is highest and it can pull oil though the valve worn valve guides.
It’s funny because I was always under the impression that it was things like smoke on decel that would tell you. I never had any of that. Just burned a lot of oil.
Old 11-24-2025, 10:55 PM
At high RPM when releasing the throttle, vacuum should be even higher than at idle. Reason why it smokes on decel.
Gilles
RoW 88 Carrera coupé
Old 11-25-2025, 01:51 AM
Mr. Merk's Avatar
We had a 3.2 that started smoking badly and it was due to a faulty ambient air valve which was siphoning oil from the tank. It was simply bypassed/disconnected. The ambient air valve's purpose is to prevent throttle body freezing in cold temperatures.
Additionally, you aren't THAT far from Kansas City. I'd refer you to JPWerks for any air-cooled repair, small or large.
https://www.facebook.com/p/JP-Werks-61556465606436/
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 11-25-2025, 06:34 AM
Compression test.
Leak down test.
And go from there. Why guess?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-25-2025, 06:55 AM
proporsche's Avatar
Originally Posted by yelcab1 View Post
Compression test.
Leak down test.
for the OP it`s most likely valve guides.As i mentioned back in 1980`-90` i have done plenty with very low mileage on 1987 low as 30K miles totaly worn out guides.I his case it is for sure.I had a friend in Germany who then confirmed to us(the shop) that they did do on 1987 some metallurgical changes to the valve guides on 87 models ---he worked at the Factory.I did hear some crazy stories from him about the production i cannot mention here...
Ivan
Old 11-25-2025, 10:14 AM
Compression test.
Leak down test.
Yep.
FWIW, leakdown was done October 2023 / 4k miles ago. All was good at that point.
Appreciate all of the insight.
-Mike
Old 11-25-2025, 03:37 PM
proporsche's Avatar
Yep.
Mike ..here is little reading for you....
https://forums.pelicanparts.com/porsche-911-technical-forum/348588-worn-valve-guide-need-help.html
Old 11-26-2025, 01:50 AM
famoroso's Avatar
Is there a test procedure for the Ambient Air Valve? A quick search didn't return anything.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 11-28-2025, 03:02 AM
Mr. Merk's Avatar
I'd imagine a vacuum test. It is controlled by the vacuum line that comes off the thermo switch on the back of the throttle body.
http://forums.pelicanparts.com/porsche-911-technical-forum/1069904-do-i-need-ambient-air-valve.html
Old 12-01-2025, 07:29 AM
PCA Member since 1988
Compression test.
Leak down test.
Ditto this. That said, I will lay bets that the compression and/or leak down will be okay. Then you're back to valve guides. As they say in the IT biz, "it's a known issue."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-03-2025, 12:23 AM
Schulisco's Avatar
The videos mainly show white smoke. In the video https://www.youtube.com/watch?v=daD9M1vtlNI, there's also moisture visible on the ground. To me, this suggests a problem with the fuel mixture or the injection system. Check the last work done on the car. Go back step by step and check what was done last. You mentioned that the car has new injectors. It's a 3.2-liter engine. I've never seen new original Bosch injectors for years for this car, as they haven't been manufactured for years. The so-called "new" injectors currently available are cheap Chinese junk. I would reinstall the old, original injectors. You can clean them if you like by using an injection cleaner additive. Also you can find videos, instructions, and experts online about how to do this.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-03-2025, 02:00 AM
