915 gearing options
It’s winter, and that means winter projects!
I’m looking to re-gear the 915 in my 3.2SS + 993SS cammed + SW chipped SC. Should have done this when we rebuilt the engine & box in May, but you don’t know what you don’t know & the 10k miles since then have given me a better take on what I want out of the ratios. I’ve read through many other threads to help guide me to where I’m at now. All gears except 5th (a longer 29:22) are currently stock for a 915/61. Car is primarily a backroads/mountain rallye car. Lots of weekends & events in WV (sweepers and some hairpins), NC (tighter, more technical) and VT (a mix). I mix in some track days & AX where I can. Problem to address: stock 2nd (1.83) to 3rd (1.26) is a big drop. 6.8k RPM in 2nd drops you to ~4.7k in 3rd, which is just below where the cam is really working. You’re trying to wring it out without bouncing off the limiter. Going to have Steve Wong set the limiter to 7.5k (have the rods & valvetrain for it) but that’s a bandaid, not a fix. No more power up there, and while it’s nice to hang onto 2nd for longer vs upshifting in some circumstances, it’d be nice to keep the car in the sweet spot of the 993SS cams. The pull from ~5k to 7k is strong. They’re good from 4k+, but there’s a real step function from 5k+. Current thinking: stock 2nd, shorter 3rd and 4th - “Option A” in the table below.
Summary of options + links to charts: Option A: Stock 2nd + short 3rd+4th ![]()
Option B: Short 2nd+3rd+4th ![]()
SCRS: ![]()
Put the SCRS ratios there for comparison, but they’re almost definitely too short for what I want. All of these look to be available via Guards (https://www.guardtransmissionllc.com/products/transmission-gear-sets/915-gears/) as well. Thoughts? Feedback from folks with re-geared 915s appreciated.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ Last edited by silverlock; 11-24-2025 at 07:42 AM.. |
I like option B. Option A (stock 2nd gear) would likely have you lugging hairpins in 2nd gear or shifting to 1st, and we all know how much 915s enjoy shifting to first. A shorter 2nd gear helps to avoid that shift.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
You're probably right. I guess I have the torque to sit in 4th so that cruising around isn't annoying.
An "Option C" with the shorter 1.933 2nd and 1.45 3rd would look like the below. 3rd goes from the 1.38 in Option B up to 1.45, and keeps RPMs up by ~200 or so. I don't know if I really get a ton out of 2nd here - in a 30MPH hairpin I'm at 2.8k vs. 3k, which is nice but still not fun. Any shorter on 2nd is even shorter than SCRS, which has the same 1.933 / 15:29 gearing as what I'm proposing here?
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ Last edited by silverlock; 11-24-2025 at 08:36 AM.. |
I like that one the best. If 1st is stock and 4th gear is at a sweet spot of 120mph @7k rpm, 2nd and third seem to be optimized as best as the ratios allow.
Interested to see what Matt Monson thinks.
It would be informative to use the engine torque curve as an input
also what rear tires? That affects the speeds. from what you posted opt 1 has drops of 42% 25% 19% 33% which outs you @ x in the next gear when shifted at 7500 x: 3918 5122 5540 4585 opt2 has drops of 42% 25% 19% 33% which outs you @ x in the next gear when shifted at 7500 x: 4557 5357 6110 5057 using the torque curve for an input allows for this sort of comparison where you can easily se that 3-5 are a bit too short
Tire size is in the linked calculators - 225/50R16 / 24.9” dia (based on the RE71RS’ I’m running) I don’t have an up-to-date dyno chart on this engine but an almost identical build (3.4 not 3.2) looks like this w/ 993SS cams and similar intake/exhaust/TB/porting mods - the blue line here: Shift point here is much more ideal at 6.5-6.8k, not 7.5k. 3.2SS/3.4SS just can’t breathe enough to make any real power > 7k. 4.5k+ RPM on the torque curve is where I want to be, which also matches my experience here. Shifting into 3rd at (e.g.) 6.5k drops you down to 4.3k, right below where you want to be. When you say 3-5 are a bit too short: expand? Which option?
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ Last edited by silverlock; 11-24-2025 at 01:19 PM.. |
(man/dude)
I've been through this a few times. This is from page 50 of my "Heavy Metal" build thread. Below, I allude to the 2.00:1 2nd and 1.381 3rd I put in my 3.2 carrera (1985 w/915), and continue to detail the 1.933:1/1.381/1.08 I put in my 3.2SS SC.
I honestly don't think there's a better way to improve the performance of, and pleasure in driving, a 911. Quote:
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
It's a 914 ...
When selecting gear ratios, remember to consider how useful the ratios will be coming out of turns - not just accelerating in a straight line. Which second gear ratio would be a more natural fit for your intended application and driving style?
I see you were also playing with a gear calculator (I should build a comparison into my chart) — your 1.933 / 1.381 / 1.081 + longer 5th (mine is 0.758, longer still) mix is very similar to the two short-but-not-SCRS-short options I’m scoping out. I have an email out to Matt Monson @ Guards (provided he doesn’t find this thread) to get his take + also confirm availability.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
(man/dude)
Here's a video of me winding out the MFI 3.2SS to 7200RPM in 1st-4th. This is a really great 915 with a Wevo gateshift and Motul Motylgear oil. And here's another one of the 3.2 Carrera, making sure to hit the (stock) limiter in 1st/2nd/3rd. It's a dog compared to the MFI 3.2SS! It's got swepco in it and doesn't shift nearly as well.
Matt just got back to me and mentioned your build. You’re also dead-on about that 2.00 2nd gear recommendation, and it’s pretty persuasive. Will be much better in low speed corners / tighter roads (North Carolina + AX) at the cost of shifting into 3rd / back down into 2nd more often (WV & less tight roads). For those playing at home, Matt recommended a 2.00 (17:34) 2nd / 1.381 (21:29) 3rd / 1.083 (24:26) 4th - Matt was extremely thorough in his reply & shared a stock vs mine vs his chart and talked me through his rationale around the RPM drops vs torque curve. I’m still tossing up whether to go to a shorter third (a 21:31 / 1.476) to keep things tighter in that 2-3 range where I do most of my spirited driving. Bumps RPMs by 350 at the 2-3 upshift though, which might be too short? 7k shift drops to 5.1k vs 4.85k. Guards recommended option: https://ratio.questionable.services/?g1=11%3A35&g2=17%3A34&g3=21%3A29&g4=24%3A26&g5=29%3A22&rp=8%3A31&td=24.9&mr=7500&sp=7000 ![]()
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ Last edited by silverlock; 11-26-2025 at 03:40 AM.. |
(man/dude)
I'll have to admit to taking a bit of a summer break from the forum... do we have you to thank for this gearing calculator? It's awesome!!!
If you're looking for notes , I miss having a vertical line from the end of one gear to the start of the other, like the old quaife gearcalc program. It really helps illustrate the effects of the ratios and the spacing between gears. It might help inform the decision you're having to make. It's starting to come back to me, the quandary I had between the 1.933 and 2.00:1 2nd, and its relation to the 1.381 3rd, and the RPM drops. To me a lot of it had to do with getting that pitch perfect sound and rythym to the shifts. I'll go ahead and claim a win on that. If I was AutoXing (like you, and me, with the '85), I would almost definitely go with the 2.00:1 2nd, and if you're regularly doing courses with 3rd gear sections, the tighter 3rd ratio. A valid argument for optimizing the shift drops in lower gear at the expense of the higher gears, is that every single time you drive the car, you use 1st gear, pretty much always use 2nd, etc. but you don't always get into 4th, much less 5th.
Thanks for the feedback on the calculator! Need to spend some time this holiday weekend building in presets for common 915 configs (915/61, early mid-years, etc), a comparison mode and definitely agree that vertical lines from the shift RPM down to the next gear will help with assessing the gaps.
Nearly all of my fun driving is spirited, spicy group rallies (Ruckus, Ruchlos, Targa Carolina, Overcrest) and as many weekends with friends in NY, PA, VT or WV just ripping around. Most of that is 2nd-3rd — rarely am I ever shifting to 4th outside of a “get to the next fun bit”. It’s a commuter gear for me. AX 4-5 times a year when I can squeeze it in around work travel & everything else. Track days maybe 2-3 times a year at best (time consuming). One of my favorite roads in NC had us hitting the limiter in 2nd, trying to balance shifting into 3rd without losing time shifting back down for the next corner, or keeping RPMs up at the bottom of 2nd on the really tight sections with a careful clutch kick to avoid bogging down below 3.5k RPM (with varying success). Getting the ratios right for those kind of roads is the goal.
IMO shortening gearing is more appropriate when the rev range has been extended, or there is some glaring deficiency in the existing gear stack.
Here's an example of a large engine power gap going through the same trans, the same gearing is appropriate for both, yes the more powerful engine accelerates better but that's not a trans issue Here's a comp I did for an E/F series chassis w/, I think a 915/44 trans used in both cases, but it could have been a stock '73RS trans, I'd need to look that up, the 993 uses a slightly higher rev limit for shifting by ~2-400 rpm ![]() In either case the gears could be shorted across the board if absolute performance was the main criteria, which it often is not.
gearhead
I left the 1.933 2nd because it was the gear you had requested. If you feel like the 1.476 stacks too closely on the 1.933 second, you can always go with the 2.00. The package that gear is actually most often used with runs a 17:35 2.06 2nd gear.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
OK, here’s where I’m at after digesting Matt’s feedback & recommendations, Bill’s advice, and thinking more about what I want out of the gearing in that 40-90MPH window.
● 2.00 2nd to make it more useful down low and bog less in tight corners. Was being too conservative here with 1.83 (stock) and 1.933 2nd as worried about the top end. Matt’s advice was to get that 1-2 shift closer + improve the bottom of 2nd in low speed corners. ● 1.476 3rd - the hardest part here. The shorter third keeps me a bit deeper into the torque curve at the speeds I care the most about, and more leeway to short shift if the conditions/road call for it. The challenge with the 2.00 2nd + 1.38 3rd is that it’s the same drop as the stock 2nd + 3rd pairing, which is the shift I want to tighten up. ● 1.08 4th - this works for me regardless of 3rd, but works a bit better with the shorter third as it drops you into 4th at 5.1k v. 5.4k. More useful at a track day (less common) vs a rally/backroads/group run (too fast). Less opinionated here. It would be nice to have infinite-ish money and time to try it all back to back, and maybe something like a (non-existent) 1.43 (21:30) 3rd would be great, but we live in a world of compromises. Critically: I am not trying to wring every ounce of power out of this car. I am mostly just trying to make it a bit spicier for the types of roads/events I enjoy the most + close a couple of gaps in the gearing that counter that. Here’s what this looks like: gear calculator link ![]()
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ Last edited by silverlock; 11-28-2025 at 05:55 AM.. |
It's also very nice to have the extra headroom so that you don' have to shift at an awkward time, like in the middle of a corner, or have to do a closely linked up then down on a straight that's just a tad shorter than the shifting likes I don't see it in your charts but its also good to look at the cruising rpm in top gear one way is to look at top speed in top if it's a ~170+/- then a 70 mph cruise will be ok, another way to look is to calculate the speeds in 5
Good points!
I’m running this 29:22 5th now / for the last 10k miles and really like it. 3200RPM @ 80MPH is well suited to east coast highways and NY parkways. Car is not buzzy and the SSI+Dansk combo is happy there and not droning.
Gears ordered from Mr Monson, who has been extremely helpful + responsive even during a holiday week. Wasn’t in a rush but at some point you can only deliberate so much.
2.00 (17:34) 2nd, 1.476 (21:31) 3rd, 1.08 (25:27) 4th. Will be a little while before they go into the car given winter & work/life, but will absolutely report back once they are. Should be late Feb + hopefully get some track time at Roebling outside of Savannah, GA to break them in ;-)
These are going to stare me in the face until February when I get the car down to SC + have Andrew Eagan drop the trans.
