Source for Kendall NS-MP 80W90? Seems discontinued...
Ran it in my old SC. Currently refreshing the 3.2 and noticed Pelican alongside numerous other vendors no longer stock it.
Anyone know if it's gone for good or did/is it getting replaced by something else?
Not looking to devolve into another oil thread. I currently have Swepco in it so yes I know there are other oils to use.
Old 12-15-2025, 10:40 PM
shoooo32's Avatar
Our host sells Kendall gear lube:
https://www.pelicanparts.com/More_Info/KENLSD7745.htm?pn=KEN-LSD-7745
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 12-16-2025, 08:40 AM
gearhead
Originally Posted by shoooo32 View Post
Not the same thing. The LSD additive doesn’t play nice with the synchros in 901, 915, and 930.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-16-2025, 08:51 AM
Matt,
What are you liking for a street 915 these days?
Rutager West
Old 12-16-2025, 04:03 PM
Not the same oil as Matt mentioned.
This is the one I'm looking for and had used previously: https://www.pelicanparts.com/More_Info/KENHYP7728.htm?pn=KEN-HYP-7728&srsltid=AfmBOor9iaKzOYGS8UC5V4RCJkUDskWEnB2GrPmz8Y SxUU_75hpeFKa9
Old 12-16-2025, 05:06 PM
walt's Avatar
Looks like JEGS has it.
Walt
82SC 3.0
81SC 3.6
Old 12-16-2025, 06:26 PM
Saw that but site shows one in stock.
Old 12-16-2025, 06:36 PM
A930Rocket's Avatar
The listing on JEG’s website says 80W-90, but the bottle says 75W-90 .Is that the same gear lube?
Old 12-16-2025, 06:47 PM
gearhead
Originally Posted by rwest View Post
Matt,
Same as I’ve said for a long time. Walmart Supertech 80w90 conventional gear oil in the blue jug. It’s made by Mobil. Valvoline and Catsrol also both have conventional oils still.
I recommend Swepco to my racing customers. But I don’t drive it on the street.
For a few years I’ve been posting about the changes to that NS Kendall gear oil. I think it was Phillips who bought them? It changed to semi-synthetic a year or two later. I hadn’t heard it was discontinued, but it might be.
1974 914 Bumble Bee
2009 Outback XT
Old 12-16-2025, 06:57 PM
https://www.drivenracingoil.com/products/conv-80w-90-gear-oil-gl4
I'm not picking my nose..I'm porting my upper intake manifold.
Old 12-17-2025, 12:46 PM
Can you order directly from Kendall? That’s how I get their oil.0
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 12-18-2025, 08:31 AM
Schulisco's Avatar
Follow the original Porsche specs for the car, not the updated specs. The updated specs say, a modern semi/fullsynthetic 75W90 or 80W90 GL5 will work. IMO only when the 915 is freshly rebuilt. All worn 915 boxes with several 100's of 1000 miles instead require old fashioned non synthetic / all mineral dino oils because of the drag torque these oils provide, to make the synchros still work.
Further readings:
https://forums.pelicanparts.com/porsche-911-technical-forum/1108783-gear-oil-recomendation-new-zealand-3.html
https://forums.pelicanparts.com/porsche-911-technical-forum/1162573-green-gear-oil.html
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-18-2025, 04:49 PM
Administrator
If the Kendall is NLA what is recommended for the early 911 boxes?
Old 12-19-2025, 08:38 PM
I had Kendall in my car for a long time but couldn’t find it when I changed it last spring, so I put Swepco 201 in it. My box was rebuild about 15 years and maybe 40k miles ago and feels good. Feels about the same with either oil.
'80 SC Targa
Avondale, Chicago, IL
Old 12-20-2025, 09:29 AM
Schulisco's Avatar
Swepco 201 is available in several viscosities. Which one exactly did you used? SAE80W90 or SAE90?
https://swepcolube.com/products/swepco-201-multi-purpose-gear-lube/ (see on the tech data sheet in the "Technical Data" tab)
Old 12-20-2025, 11:53 AM
HarryD's Avatar
On the recommendation of Steve Weiner and Jeff Gamroth, I have been using SWEPCO 201 80W90 since I bought the car over 24 years ago. Approximately 76,000 miles later, still going strong.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-20-2025, 12:10 PM
Administrator
On a 911 gearbox, i.e. the transmission before the 915?
Old 12-20-2025, 02:47 PM
Schulisco's Avatar
Check this website:
https://blueskymotorsports.com/
Old 12-20-2025, 03:07 PM
Administrator
That site has some nice articles but I'm just looking for a recommendation for a current gear oil that is correct for a 911 gearbox
Old 12-20-2025, 04:08 PM
Schulisco's Avatar
That site has mentioned in the transmission lubrication pdf that the original factory recommendation gearboxes is an all mineral SAE90 (GL5). Afaik this is valid for the elder 901 gearboxes too. Only the filling capacity differs. Porsche afaik filled originally Shell Spirax MB90. There are datasheets available for this. Choose an oil with comparable specs. As others wrote above the Swepco 201 80W90 is probably a good choice. It has comparable specs to the Spirax MB90. As long as the gearbox oil is an GL5 (mandatory) you can use any oil. But dino oils like all mineral SAE90 or 80 to 85W90 should do the trick. Key are the viscosity values separating a good shifting 915 from a not so good one...
Old 12-20-2025, 04:40 PM
