Guardsred911's Avatar
Oil Tank Cleaning
I had this hot tanked and cleaned along with the oil cooler (not hot tanked as it’s too caustic for aluminum).
I am super happy with the results. But want to do a final cleaning on the inside of the tank. Thinking slosh a bunch of diesel around inside til clean?
J
911 SC - 1980
911 S - 1977
Old 12-23-2025, 03:59 PM
Shaun @ Tru6's Avatar
When I Cerakote tanks, I use acetone sloshed and spilled out until it runs clear/clean.
Tru6 Restoration & Design
Old 12-23-2025, 04:25 PM
Perfect. Thank you!
J
911 SC - 1980
911 S - 1977
Old 12-23-2025, 04:37 PM
PCA Member since 1988
Acetone is a great solvent. I would use something cheaper and less volatile first. If there's still crud in it, then go for the stronger solvents. Gasoline works very well too. Of course, keep the fire extinguisher handy when working with any volatile solvent.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-23-2025, 05:37 PM
Ah. Good idea. I sloshed some acetone around and got most out- it was hot tanked so pretty clean already but I think the more I can clean it the better.
J
911 SC - 1980
911 S - 1977
Old 12-23-2025, 05:55 PM
A930Rocket's Avatar
Would it be beneficial to throw in some small bearings, nuts and bolts, in addition to acetone/gas/etc. to remove any baked on debris?
Old 12-23-2025, 06:35 PM
That should have been the first move if there was any surface rust seen with the scope ..
Old 12-23-2025, 07:21 PM
It’s stainless steel, which is nice.
J
911 SC - 1980
911 S - 1977
Old 12-23-2025, 08:26 PM
I’m not sure it is stainless steel, I think it is more likely rust-resisting steel. I have seen these corrode through
Old 12-24-2025, 12:03 AM
A930Rocket's Avatar
I was thinking it was steel, because of the brass (?) hose connections welded/soldered to it.
Old 12-24-2025, 08:08 PM
If you are careful, gasoline is probably the best solvent to use in the oil tank. It was the only thing that got rid of the brown buildup inside mine. Don’t add any ferrous metal nuts, balls, etc though….ignition hazard.
Old 12-25-2025, 05:44 PM
