Sent from my SM-G988B using Tapatalk |
It's the stock 214 hp engine with the catalytic converter. Chip is 28 pin.
Sounds to me like engine is still being fueled on overrun condition. I would recommend checking the microswitch on the throttle body to be sure it's adjusted correctly. This switch signals a closed throttle condition to the ECU during overrun which shuts off fueling to the engine, eliminating any bucking or exhaust popping. Also assists in engine braking.
