horn grill rally light brackets
Could anyone tell me where I might get a set? I don't care if they are original or reproductions.
Thanks Allan |
Allan,
There are two types that I know of. 1-- Lights mount directly to the grill. 2-- Bracket comes through the grill for the lights to mount to. (see photos) I see repro of both styles on eBay every so often, originals - NLA, so pretty tough to find. ![]() ![]()
'04 BMW R1100S BCR '01 Audi TT RS gone but not forgotten: '87 911 Carrera '59 356 Coupe '66 912 Speedster '99 996 Ducati |
Senior Member
My 72 model that I owned in Germany came with lights in the horn grills. The grills appeared to be standard models that had the "fins" cut out to allow the light post to mount to a metal piece that bolted to the tub of the car, and not the grill as shown in the top picture above. It was like in the the lower set of pictures.
Believe that it would not be that difficult to find a set of repro grills, cut the required grill out and mount a set of lights as I described. JoeA
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
My brother manufactures thru the horn grille brackets.
Email me if your interested: jtkkz@comcast.net Price is $100.00 plus UPS shipping Very high quality reproduction, black powder coated I have sold a few of these to Pelican members. Pic ![]() Last edited by jtkkz; 08-31-2004 at 08:06 PM.. |
pic of my 73 with thru the horn grille brackets and lights
![]() another pic of my 73 newly installed brackets and lights without cutout grille installed yet ![]() |
I notice in all these pictures that the lights are the thin cased lights. Will the lights with the larger housing fit on the horn grills as well - they are the ones you usually see mounted on the hood?
Thanks for the initial info. I will send an email about thse brackets. I need to purchase sone lights first though. |
I would rather be driving
The lights that are typically mounted through the grills are the Hella 118s (original). A newer alternative ar the Cibe Tango 40s. the larger lights that you mention are the Cibie Oscars. these can be mounted to fit but will usually require different brackets. The Oscars have a much different housing and the bracket must stick out more to clear the grills.
YOu can do a search on grill mounted lights and fine quite a bit of information. good luck.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Hood mounted lights are very different, they are much larger.
pic of my brothers car with hood mounted NOS lights. ![]() Those lights that I have used on my '73 were just inexpensive generic lights that i bought online. (Pro-Comp brand) I bought something inexpensive this way if it cracks or breaks I do not feel so bad. Real 118's are very expensive. My brother has also made custom made brackets for some friends at rgruppe for there baby oscars (thru horn grill). Pic of custom made thru horn grill brackets for baby oscars. ![]() The ones we sell are for the standard 118's or something generic that is close to the size of the 118's. Hope this info helps |
For anyone wanting to do this, I have a set of PIAA #510s I had mounted on a '73 E that the purchaser didn't want.
I have the lights/brackets and cut-out black horn grilles (not elegantly cut, though). They bolt to the factory-style brackets, which mount on the battery boxes. PM me if you want to buy them. ![]()
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Senior Member
Tech,
Just sent you a PM. Joe
The 'Hood lights' have a flat base, see photo. PS..real hard ($$$$) to find. ![]()
i got mine from jtkkz
they fit perfect and were just the ticket ![]()
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Skinnerd
Thank You for posting pic, looks good , nice car. |
mine is green ,too. Everybody calls it "the frog".
There are 11 sets left in stock, anyone interested please email me at: jtkkz@comcast.net and let me know.
Thank You |
Found a pic of a thru horn grill brackets with fog lights and grill that I cut myself.
