Czar of C.R.A.P.
dfink's Avatar
seam sealer or undercoating
The forums have gotten so large and filled with so many words that simple searchs seem to yeild hundreds of pages of posts with very little relevent to what a person is looking for anymore. I am sure there is a perfectly good answer to this if I use the magic combination of words but someone can answer and save me the 4 hours of reading about cleaning wheel wells or removing seam sealer.
Anyhow welded in the cage and at both front and rear fenders the coating in the wheel wells was burnt off by the welding. The wheel well coating doesn't appear to be a tar based undercoat like that found on some cars. To me it appears closer to the seam sealer removed from the inside. Should I just brush off the burnt material and cover with seam sealer or is there an actual wheel well coating, What is there peels off like some sort of latex / rubber material.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 12-29-2008, 04:29 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Try Wurth High Build Underseal
http://www.autogeek.net/wuhibuunun.html
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 12-29-2008, 05:38 AM
burgermeister's Avatar
The wurth sks is pretty close also. I think 3M has a similar product, the name of which I can't recall. The wurth stuff is water based, which makes it a breeze to spray (I used their "schutz gun") and clean up.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-29-2008, 07:37 AM
