Ball studs
Does anyone know where i can purchase a 5mm bolt on ball stud?
I have a 911 T engine in my VW bus and i need to slightly change the geometry on my throttle linkage. i need to drill a hole in one of my linkage plates and add a ball stud so that i can get full throttle out of my PMO's. I think ball stud is the proper term. You know it fits into an adjustable socket on the end of a linkage rod. All the ones that i can find seem to be the type that are peened over on the back side.Any help on this would be greatly appreciated. Cheers |
grind off the peened shaft and silver solder a 5mm bolt onto the flange below the ball.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-12-2011 at 09:21 AM.. |
I was hoping to avoid that.I guess i could have a machinist drill out a 5mm ball bearing and thread a stud into it.
Maybe you can source something from this supplier: Home - Midwest Control Products Corp. Sherwood |
Hi there
I think these guys make what you want: Home; Illston and Robson.com; Manufacturers of Balljoints & Airline Couplings Maybe they have a local supplier Cheers Nigel UK
'70 2.2S Silver. Its GREAT. '87 3.2 Coupe '89 962 Sadly sold '79 935 K3 Also gone |
I the ball stud has a 5 mm threaded section but the ball is larger I have a few, with or without the socket end.
Lorne M.
83 SC |
Navin Johnson
The smallest McMaster Carr has are M6 ball studs...
You can get them from PMO if needed..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thanks for the input. The ball itself is 5mm. I will try PMO.
Seems like such a simple item. I'm surprised noone has these on the shelf. Cheers |
