DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Targa Seals
Has anyone had any experience reusing their front and rear targa seal after removing? I had to remove both when I did a brown to black upholstry conversion, both broke but seam to be on an existing seam that I can redo with intube patch cement.
Question, am I wasting my time? Should I bite the bullet and spend the $400 to replace both and endure the trial and error for cutting and fitting the front seal ( I know I have CarsInc. Dan Owens words of wisdom on how to do it)?
I would love to reuse the existing seals and let this be a future project/expense, any experience out there?
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 05-16-2005, 03:19 AM
Heck, I’m only 5 not 71!
targa80's Avatar
If you are satisfied with the condition of the seals then I see no reason why you could not reuse them. Just make sure the seal and surface are very clean and you use a quality trim seal glue to reinstall.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 05-16-2005, 03:35 AM
What kind of glue are you planning to use to repair the seal? I've had some success with plain contact cement, but I haven't tried that on a large area or one that constantly flexes.
CConnor
73E targa
89 Coupe
Old 05-16-2005, 05:22 AM
Has anyone found a nice way to replace the cloth on the rear targa bar seal. My seal is in pretty good shape but the cloth is gone and it seems to help with the windows sliding smoothly.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 05-16-2005, 05:37 AM
DonMo's Avatar
I intend to use the same glue you use to patch automobile or bicycle tubes. It is real strong and should work fine.
DonMo
Columbia, SC
"Go Hokies"
Old 05-16-2005, 06:59 AM
