randywebb's Avatar
lock washers on starter mounting studs?
Should I use lock washers on the studs for mounting the starter?
I'm not find ing any info on this in the PET, the catalog or in any threads...
My car had a flat washer on each stud - but no lock washer. It has a 3.2L engine in it but uses a 1971 (911 type) transmission.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-09-2005, 05:13 PM
walt's Avatar
Mine also had flat washers and replaced with same. Couldn't hurt to replace with locks.
Walt
82SC 3.0
81SC 3.6
Old 06-09-2005, 06:01 PM
originaally they were spring washers. You know, the wavy kind. I'd go with a lock washer if you do not have the spring washers.
69 911 2.3Ez
85 928S
Old 06-10-2005, 12:00 PM
