Send a message via AIM to Dionikes Send a message via Yahoo to Dionikes
Misfiring at idle
Ok, I have done several searches on this issue and I believe my problem is worthy of a thread.
I have been working on baselining my 911. This last week I replaced spark plugs, Clewett wires, cap and rotor. I also reset the valve guides.
Now I did this all backward. So I managed to change plugs and wires before I did the valves. I am retarded like that. So any it ran like a caged animal after I did the wires.
Yesterday we did the valve job and changed the rotor and cap. After we put everythying together it ran rough and after a couple of minutes started misfiring.
Troubleshooting done so far:
- ensured wires were seated on cap and plugs
- double checked order of wires in both places
- checked rotor postion at TDC
- checked the valve clearances twice before reassembling
What can I rule out? What can I check next? Any ideas? I know there have been problems with Clewett wires in the past...is it possible they are not seating?
Thanks for your help.
A blog on my '87 Targa
http://porsched.blogspot.com/
Other ride:
'03 BMW 330Ci
Old 06-22-2005, 01:57 PM
B D B D is offline
B D's Avatar
Very basic but did you check or reset the timing, you did not mention that in you post? If not check it.
68 911L
Old 06-22-2005, 02:18 PM
kqw kqw is offline
Setting the timing on the Carrera is not necessary....
The Fox
Carrera
Old 06-22-2005, 03:53 PM
kqw kqw is offline
Before you go back to re-check the valves,
I would put the old wires on again to eliminate an issue with the clewetts.
The Fox
Carrera
Old 06-22-2005, 04:05 PM
I had someone check my work. I had the 4 and 5 wires crossed. I felt like a total retard. Thanks for the reponse guys.
Other ride:
'03 BMW 330Ci
Old 06-23-2005, 05:07 AM
I understand how easy it is to cross wires even when being as carefull as possible. So the question I have is why aren't the wires numbered to prevent this from happening?
I assume that Clewett wires are not numbered so how expensive would it be for these wires to come with numbers?
I suppose it's just as easy to number the wire ourselves with a ballpoint pen on both ends of the cable if I ever run into wires that are not marked.
Joe
Old 06-23-2005, 05:12 PM
The wires are numbered at the dist cap but not at the plug end.
Other ride:
'03 BMW 330Ci
Old 06-23-2005, 05:16 PM
kqw kqw is offline
Just a question folks....
Why are Clewett's and Magnabore's being considered over the original Bosch wires and connectors. My original Bosch wires lasted almost 15 years before they were replaced (again with original Bosch).
I see where folks struggle with fit, connections, separators etc....
Why go through this????
Again, just a question.
The Fox
Carrera
Old 06-23-2005, 06:11 PM
OE Bosch? I thought Beru were OE at least from '73 on.
Joe
Old 06-24-2005, 08:35 AM
MSD's require a high level of EMI suppression to ensure that the ignition is reliable to 6K and beyond. Porsche uses solid core wires and puts their suppression into the notoriously unreliable Beru plug connectors. While its OK in some applications, using spiral-wound suppression wire works much better and prevents some misfiring issues that occur at high RPM.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
http://forums.pelicanparts.com/showthread.php?threadid=223673&perpage=20&highlight=msd&pagenumber=2
Old 06-24-2005, 08:45 AM
Designer King
Paulporsche's Avatar
How can a car run like a caged animal (assuming you meant after it has been let loose) before the valve adjustment with the wires incorrect, but run poorly once the valves have been adjusted, with the wires still incorrect? Can anyone explain that?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-24-2005, 08:49 AM
The wires were right before thevavle job. I screwed them up when I put them back on. ;-)
Other ride:
'03 BMW 330Ci
Old 06-24-2005, 03:18 PM
kqw kqw is offline
Sorry...Beru...instead of Bosch...
The Fox
Carrera
Old 06-24-2005, 06:16 PM
The Clewett plugs did not give me any trouble really. It was simply pilot error
Other ride:
'03 BMW 330Ci
Old 06-24-2005, 07:51 PM
