-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   1987 Fuse box diagram help (http://forums.pelicanparts.com/showthread.php?t=229431)
darnell 07-04-2005 11:40 AM
Could someone please post or tell me where I might find a picture or drawing showing what each fuse and relay is for
in my 1987 Carrera? Yes, I tried to search.
Also, why would the cooling fan for the oil cooler always be on when the key is on?
Thanks in advance.
nreed 07-04-2005 11:44 AM
give me your email and I'll send you all the schematics.
nreed 07-04-2005 11:46 AM
woops...I thought you had a turbo. I can still scan in the carrera fuse block diagrams.
strupgolf 07-04-2005 01:52 PM
is it not on the inside of your fuse box cover? My 86 has a diagram there telling me what fuses go to what. 2cworth.
darnell 07-04-2005 02:48 PM
No. I don't have anything inside my box cover. That's why I need help.
Thanks.
Seeeu911 07-04-2005 02:55 PM
This is great !
nreed, I also have need for the fuse diagram ! can you please email me scan as well ?
seeeu911@hotmail.com
Thanks !
imcarthur 07-04-2005 03:02 PM
Here's a Bentley scan. Probably a worthwhile purchase for you.
http://forums.pelicanparts.com/uploa...1120514489.jpg
Relays to follow. . .
imcarthur 07-04-2005 03:06 PM
http://forums.pelicanparts.com/uploa...1120514773.jpg
Seeeu911 07-04-2005 03:08 PM
thank you very much imcarthur, agreed ...the Bently is on my short list to purchase.
darnell 07-04-2005 03:12 PM
Thank you. I knew someone would have it! I have a Bentley on order.
Thanks again!
BSD
pinkmechanic 04-10-2015 05:17 PM
porsche cabriolet 1987
my convertible roof wont close :-((...i suspect the fuse...can someone tell me which fuse is guilty? i have no extra fuses therefore i will make a switch until the stores open tomorrow. which fuse can i switch around to be able to close the roof urgently?? thanks for your help..
billjam 04-11-2015 07:44 AM
It is the 25A fuse, third from the rear of the fuse box.
You could swap out any of the other 25A (blue) fuses except for the fuel pump fuse (6th from the rear).
http://forums.pelicanparts.com/uploa...1428763392.jpg
doc911 09-15-2018 08:47 AM
Dear imcarthur,
It might sound a bit too late but, thank you very much, indeed for the chart.
I've recently used it in my 1987 Carrera Cabriolet.
Fahad
doc911 09-15-2018 08:51 AM
Dear imcarthur,
Fahad
