Space saver tire question
I just got this 964 alloy spare wheel with space saver tire (because it’s lighter).
Compared to my stock steel spare the tire is much wider in diameter, rubber seems stretched out, or is that normal? There’s no air left in it. Guess I have to swap the tire on the rim to make it fit in the frunk? ![]() ![]()
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Isn't that the point of the space saver? You air it up when it is needed in order to drive. I inflated mine to check, though later I did think, what if that rubber had been old and blown apart?
https://www.instagram.com/p/BX-iojjnEAP/?utm_source=ig_web_button_share_sheet Last edited by toddetch; 09-13-2018 at 11:52 AM.. |
? I want to make it fit my SC frunk
flojo it will fit ....you just need to get the spacer from polyester..
this one
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Yeah, maybe you're missing some spacer or something like @proporsche suggests. That tire in my video is the original spare in my '80 SC.
I found that the deflated tire diameter of 15 and 16 inch tires is the same, so the tire that you are showing should have the same diameter and should fit in the trunck. Check both topics specially the second one.
http://forums.pelicanparts.com/porsche-911-technical-forum/357045-collapsible-spare-tire.html http://forums.pelicanparts.com/porsche-911-technical-forum/176952-collapsable-spare-fuchs-2.html Last edited by donporfi; 09-13-2018 at 01:31 PM.. |
Put a strap around it and cinch it back down to fully collapsed size with the valve stem out.
'74 911S 3.2 '71 911T 2.4 |
Get a 930 or 491 spare they are AL.
Diameter of Kronprinz is 50cm
Diameter of Alloywheel is 52cm. It doesn’t fit in the space around the tank. I will swap the tire. Btw: 2kg weight saving
Flojo you cannot replace the spare wheel tires..rubber if it is Vredestein type
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 09-14-2018 at 01:20 AM.. |
? please explain!
does the Vredestein off the Kronprinz wheel not fit on the 964-alloywheel? or does the Vredestein break when removing off the rim?
i am pretty positive you cannot remove the inflatable tire from the rim it self .It is one piece...
Give Harvey Weidman, Weidman's Wheels, a call. He is the authority on what will and won't work on rims/tires. I know he is installing a space saver tire on my 15" deep six Fuchs spare.
'71 914-6 #0372 '17 Macan GTS |
so the tire MUST come off and is refittable to other rims. stay tuned, I have the wheel with me for the tire guy this evening, I let you know...
Step 1, it came off easy
Formerly known as Syzygy
I also have one of the Vredestein spares installed onto a Fuchs wheel.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 09-14-2018 at 11:40 AM.. |
Flojo,
The problem is with the tire diameter or with the rim ? |
There are a lot of myths regarding removing an inflatable tire from the wheel and mounting it on another rim.
Most of the time the guys at the tire shop do not want to do it and they give a false answer. Other myth is that if you inflate it , it will never return to it's original size. |
here you go Flojo i did not know that ..actually never worried about it..good for ya
Ivan
cool - I learned something today
