special tool? oil pressure sender..
got my new oil pressure sender in the other day from the pelican. not sure, but i'm thinkin' i'm going to need an odd tool to remove old and put on new..what will i be needing for the job, guys? thanks.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
thanks, jim..jeez this reads like a pita..looks like i'll be needing to head to sears for a crowsfoot..hope my '74 uses a 24 mm like the others in the link you attached.
ryan
Read the entire thread and links; I do not recommend using the crows foot!
Take the mounting block out and put it in a vise; then unscrew the sender. Jim |
will do, jim..thought i saw something about what you'd written along those lines while quickly scanning the thread. didn't sound like i;d need speacial tools either..maybe just removing the a/c compressor, etc. for clearance..
ryan
Read the thread, but the short version is - remove ac compressor, remove ac bracket (alas you need to remove the muffler for that), remove oil line, remove block. The only "special" tool you'll need is a 27mm wrench.
Just did it myself. PITA, but easy. Stef |
27 mm wrench?? damn, i think i have a 27 mm socket..isn't that what we use to remove the steering wheel??
ryan
Once the mounting block is in a vise one can likely use a big open end adjustable wrench (Cresent wrench) or even a Stilson wrench (Monkey wrench).
so you just loosen the nut to the adjacent right of the block, slide the block out i'm guessing and remove and replace sender on the vice?
ryan
See below thread for image. Loosen right oil line and then back off the hollow union bolt- item 3 (probably what you think is a nut).
http://forums.pelicanparts.com/showthread.php?threadid=169602&highlight=sender |
And brace yourself when you chuck it in a vise... we had 500 lbs of middle-aged humans on the greasy garage floor...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
The problem is the clearance between the block and the sender. The wrench barely fit, my adjustables didn't. 27mm is larger than you think, the smaller ones won't open that wide.
Also as randy implied - you'll be REALLY leaning on that sucker to get it loose, so the adjustable ain't that great. Try not to smack anything when it comes loose. I don't remember what I nailed, but I remember that it hurt Have fun! Stef |
