spacers / adapters sizes?
What are the sizes available on rear spacers/adapters?
Is there any size between 2" and 3" like 2.5"? I cant find anything in between 2" and 3". I need 2.5 or 2.75.. |
I recently bought some 57mm's from a fellow pelican I believe they are H & R 's and they are 2 1/4 inch each side.
Thanks for the reply. I'll check with H&R.
What you can do (more work and more cost) is put a smaller spacer in (say 19mm) and then go with a hub centric adaptor to get you the additonal 2".
do a googles search for boothe he will build you any size you need, Kevin
Thanks!
Thanks Kevin. That solves my problem!
FYI here's the link to boothe: http://www.boothedesign.com/spacers.html |
I have his spacers they are great, Kevin
| All times are GMT -8. The time now is 03:11 PM. |
