Virginia Rocks!
A "tip" on sparkplugs
You would have though I learned my lesson in May. A refresher for those that missed it:
http://forums.pelicanparts.com/showthread.php?threadid=223679&highlight=plug After discussing it with another fellow, this is a common problem - the vibrations shake the tips of the plugs off. Attempting to diagnose another problem today I found that it happened again. The tip came off and fortunately this time was trapped in the end of the spark plug wire. I was able to get it out with little effort. So the "tip" on tips is to ensure those things are on there gorilla tight. You cannot retreive them with a magnet if the fall off.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Wow, isn't anything easy?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Virginia Rocks!
