rfuerst911sc's Avatar
lighting issue-what's going on here?
The other day I was driving my 83SC in traffic and I noticed when I stopped a light reflection in the car bumper ahead of me, as it turns out when I apply the brakes my passenger side front turn signal bulb lights up! I have removed the side running light to install a oil cooler scoop so it's not that light it is the turn signal light. Do I have a bad ground? Any suggestions?
Old 12-20-2005, 03:58 AM
DW SD's Avatar
I would guess that you may have single filament bulbs in the rear taillight housings where you should have double. The rear tail lights have two filaments, 1 for brakes, 1 for running light. When you hit the brakes the lights power up the other circuit. Just a guesss.
The single filament bulbs have their connector to positive in the middle, where the double filament bulbs have two contacts, but considerably offset from the center of the bulb. That center contact can connect both circuits.
1971 RSR - interpretation
Old 12-20-2005, 08:32 AM
NO NO you got it all wrong....You have a front brake light out on the drivers side!
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-20-2005, 08:43 AM
