XLR8'd Member
David 84 911's Avatar
Coupler bushings replacement...does it come apart?
I made it through the shifter bushings replacement (relatively unscarred)...but I will be darned if I can figure out how to change those in the coupler, does it even come apart?
Cheers !
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 01-10-2006, 05:55 PM
push out the pin using a vise. use a bolt or something smaller than the pin on one side and a large socket on the other to receive the pin.
206 637 4071
Old 01-10-2006, 06:20 PM
North Coast Cab's Avatar
Check out these brass ones. www.esells.com/ecitemlist11.asp?CO=NC&CMD=SRCH&AIMCID=4937&AIMDID=44409
I wish I hadn't done mine already.
John
1985.5 944 GTS
Old 01-10-2006, 06:27 PM
Mookster's Avatar
I purchased the brass bushings from our host.
I do notice more tranny noise in the cabin since this upgrade. I replaced an the bushings. no more slop.
You need to punch out the pin as JW mentioned to replace the bushings.
If it has a skirt or tires, it WILL cost you money!
Old 01-10-2006, 07:21 PM
I've posted on this before... I prefer the "firmer and less-slop" press-in 914 hard plastic pieces over brass.
Why?
The action of the joint requires a true universal joint. The brass restricts motions to one plane..it doesn't "work" like a true universal. The hard plastic will be "better" than the slop unit used for 911's...yet will "give" a bit better than brass. OR...use a true universal like the Stomski unit and such....
The possible consequences of "forcing" a brass unit beyond it's movement limits is add'l trans wear...
Do a search...there is a long thread with pro's / con's of each method described.
- Wil
EDIT... look what Wevoid and Chuck Moreland have to say here-------> http://forums.pelicanparts.com/showthread.php?threadid=128478&highlight=shift+coupler
...not many are heeding this sound advice...
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-11-2006, 07:51 AM
XLR8'd Member
Given that it is an easy job and I already have the "plastic" bushings, I might as well put them in rather than put them in my "left over porsche parts box". Thanks I appreciate the help, I don't know where I would be without this site....(probably driving a Civic).
Old 01-11-2006, 10:36 AM
