-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   blasting materials (http://forums.pelicanparts.com/showthread.php?t=266439)
bbaer6676 02-14-2006 11:15 AM
blasting materials
I recently bought a blasting cabinet, what would you guys suggest i use to clean my heads etc. glass beads maybe? what size?
brian
Scott Clarke 02-14-2006 11:23 AM
Brian-
I use a medium grit glass bead. This is aggressive enough to work without being likely to quickly damage stuff. Be sure to wear a respirator when you use the cabinet, particularly with anything that is cadmium plated. Also, I strongly suggest that you blast outdoors. It makes a mess!
-Scott
RickM 02-14-2006 11:24 AM
Yes, glass beads. Eastwood sells 70-100 grit for this purpose. They recommend no more than 60 psi pressure.
http://www.eastwoodco.com/jump.jsp?itemID=1313&itemType=CATEGORY&path=1%2C2% 2C1310&KickerID=243&KICKER
Grady Clay 02-14-2006 01:14 PM
Blasting media comes on all sorts of forms depending on function, cost, environmental conditions and more. It can vary from glass beads to nut shells to lead or steel shot, to solid CO2 and much more. The important issue is to match the media, technique and subject part to achieve the desired result.
I won’t claim to be an expert but over the years I’ve done a lot of this. This would be a good thread to review all the media, techniques, etc.
The four areas I am sort of familiar with are:
Stripping of some prior finish.
Cleaning of dirt, baked-on grease and corrosion.
Preparation for a surface finish (plating or painting), this is different from above.
Stress relief (connecting rods).
How about some expert input. :)
Best,
Grady
911mot 02-14-2006 01:58 PM
What would you use to do fuchs?
bbaer6676 02-14-2006 02:23 PM
im trying to remove old paint for new paint on some parts and powdercoating on others.
Hetmann 02-14-2006 02:34 PM
I think blasting is a hoot. I'm no expert, but I get a real kick out of doing it.
NY65912 02-14-2006 04:12 PM
It depends on what you are doing to the Fuchs. Are you blasting off anodising or paint and do you want to achieve a finished product from the bead blaster.
Be careful, go slow. Try to use the least abrasive beads that will still get the job done.
I've use glass beads on everything, the only thing is varying pressure and using all sorts of glass beads and combinations.
Good Luck.have you done a search yet?
ozz 02-16-2006 09:55 AM
FWIW - I've purchased from these guys and have had good service.
http://www.kramerindustriesonline.com/contact-us.htm
Their site is informative regarding what products are available (I didn't know that people blasted with walnut shells!!).
Also you can give them a call and talk to them about your application. I did and the fellow there gave me plenty of information on various materials and eventually recommended that I go with "fine" glass beads for what I typically need to do which is remove old paint and light corrosion from mostly aluminum parts.
