Lots of oil in the intake, any ideas??
My 90 C2 used to be fairly dry, but last year it started leaking from what appeared to be, well, everywhere! Front, back, sides, top, bottom... it looked like all seals gave up the ghost at once. However, upon further investigation it looked like all the leaks were originating up top, on the bottom of the intake then running down all over the place. So I opened up the intake and sure enough, oil was everywhere and was pooling at the bottom of the manifold.
Surprisingly the car doesn't smoke at all, not ever after sitting for long periods. I even had a friend follow behind and watch closely on acceleration and deceleration, nothing.
So what gives, how could all this oil end up so high in the intake? I see two hoses coming from the oil tank that tie into the intake, one for crankcase ventilation I assume, but what's the other small one?
One last clue, if I fill the oil when warm to mid dipstick, it seems to leak much worse. I have to run about 2 quarts low all the time, otherwise I get so much oil leaking that it starts to smoke at stoplights.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 11-19-2016, 09:08 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Over fill of oil, what is the oil level when she is hot and at idle? not warm but hot.
Check to insure dipstick is the correct length.
'85 Carrera Targa
PCA/POC
Old 11-19-2016, 09:56 AM
Maybe, but I don't think so. I've been fighting this for about a year now and run the oil really low, still have the issue. Hot at idle I only fill it until it just touches the bottom notch, about 2 quarts low best I can tell. If I fill it to the middle things seem to leak much worse.
Past:
Old 11-19-2016, 10:14 AM
DanielDudley's Avatar
What oil are you using ?
Old 11-19-2016, 10:16 AM
DRACO A5OG's Avatar
Have you replaced the breather hoses coming from the oil filler neck, should be similar design, no?
'85 Carrera Targa
PCA/POC
Old 11-19-2016, 10:28 AM
Brad Penn 20/50.
No, haven't replaced any hoses. I've had a number of older 911's, but this is my first 964, so I'm not sure what the purpose of the two hoses are, vs just one, but I'm wondering if one of them were clogged or something and I'm getting positive pressure in the tank and it's feeding back through these hoses??
Past:
Old 11-19-2016, 10:33 AM
+1, as Draco says, make sure you have the correct dip stick. It sure sounds like the one you have is too short, or it is not fully pushed into place.
Old 11-19-2016, 11:17 AM
That's a good thought on the dipstick. I checked and looked at pics online of 964 dipsticks, that's the one I have. It's fully seated as well, and also corresponds with the dash gauge, i.e. if it's at mid level then the gauge reads mid level. The way I run it now the gauge just starts to move, but is at the very bottom of the range, same for the dipstick. (All checking done at warm idle btw)
I'm really feeling like I'm getting positive pressure in the tank or something and it's bleeding backwards via the breather hoses?
Past:
Old 11-19-2016, 11:32 AM
Do a leakdown test to make sure your rings & pistons are all healthy.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2016, 11:42 AM
Administrator
Jack Olsen's Avatar
Is the cone-shaped restrictor present? What happens to your idle when you open the oil tank up?
Old 11-19-2016, 11:48 AM
Do these cars have a PCV valve? It might be that.
Old 11-19-2016, 12:57 PM
Not sure, where would I find it?
I'll have to check on the idle when I get it back together, but I don't recall it changing much when opening the tank fill.
Past:
Old 11-19-2016, 01:31 PM
Wouldn't I have a smoking issue then, and likely oily plugs? And would type of issue bring this amount of clean looking oil up so high in the intake?
Past:
Old 11-19-2016, 05:42 PM
