Cali 911's Avatar
Lightbulb Help with tire size
I have 6's & 7's now, and they will be replaced with a set of 7's polished up front & 8's in the rear. I have SC flares now. Any tire size and brand recomendations?
Old 04-26-2006, 07:25 AM
IROC's Avatar
A search will yields volumes of information on this subject.
Having said that, 205s and 225s still work really well on 7s and 8s. Tire brand, etc., really is a function of your budget and needs...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-26-2006, 07:43 AM
Not sure if you want to roll your front fenders, but 225s could fit up front. You may need more negative camber also.
Not sure if SC flares are the same as my rears, but I have 8s with 245s. I also put 5mm (?) spacers in the rears and have some negative camber, but I think the set-up should work as long as your SC flares are the same... anyone out there know?
Brian
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/showthread.php?threadid=285064
Old 04-26-2006, 10:13 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Check out this wheel fitment chart. It has just about all the info you need.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 04-26-2006, 10:46 AM
