pablo marquez
Guest
Posts: n/a
Ign. Wire Diagram
I am having a horrible time with the inc. switch and the assoc. wiring.
Does anyone know what the diagram is for the ing switch?
I have replaced the elc. switch and now every once and while the car just won't start. Juice to everything (inc. fuel pump and solenoid) but the darn thing will not turn over.
Thanks for any help.
Old 05-15-2006, 03:49 PM
vizail's Avatar
Pablo
I'll really like to help you but .. can you be more specific?Sound's like you are not getting a good siganal to the Starter Selenoyd.
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_Part1-1.jpg
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_Part3-2.jpg
Vic
Old 05-15-2006, 04:38 PM
pablo marquez
Guest
Posts: n/a
HELP...Please
Ok, 1981 911 SC
I had the ing. switch go out a month ago...struggled to get those headless screws out, switched everything over and it woked fine for a month. Now I stoped the car to put in gas, and went to start it and everything has power but it won't turn over. I had this problem when I first did the R&R on the switch and it was one of the plugs that go into the tub. Moved it around and it was right as rain...until now.
HELP...Please
Old 05-15-2006, 09:32 PM
my car has a 3 way yellow wire connector that branches to the AC comp & solenoid in the trunk under the windshield area on the drivers side. Then there's the engine comp 14 pin connector.
I'd say that if a temporary starter jump was hooked up when this happens and the jumper turns the starter then it's a connector. I just roll under there and use a screwdriver to jump the solenoid.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-16-2006, 03:47 AM
