What alloy?
All,
Does anyone know the aluminum alloy used by Fuchs? I need to give a potential anodizing source some details to determine their suitability... TIA, Chris |
They are Magnesium, not aluminum. If your potential annodizing source didn't know they were Magnesium, consider Al Reed refinishing. I tried several places in Atlanta that turned the work down at any price.
do a search using "Al Reed". He is far cheaper than any of the local shops I talked to and does excellent, consistant work. |
Sorry -
didn't notice you are a senior member. I'm sure the reference to aluminum was a mistake. And you are aware of Al Reed and how the search button works. I'll stop typing now... |
Fuchs are magnesium? Don't think so.
Sherwood |
In a thread titled "DIY Wheel Refinishing", dvkk wrote:
:rolleyes: Steveinatlanta, Don't sweat it. Sometimes we all miss things. Chris |
So?..... this ( the Fuchs) is still an aluminum alloy wheel...what does a fraction of 1% Mg have to do with calling this a magnesium wheel?...
Now the 5.5 x 15.... " gas burner" wheel....that's another story.... - Wil |
ALUMINUM...
Q: Can you tell me what aluminium alloy was used in the Fuchs Porsche rims of the 60s and 70s? A: We used 6082(USA), 3.2315(DIN), AlMgSi1(Type) or FUCHS Designation AS10.62, .62 indicates Temper Disignation. Best regards Joachim Boehme EN AW-6082, 3.2315 typical mechanical properties 0,2% Yield strength Rp 0,2 240-310 MPa Ultimate tensile strength Rm 250 MPa Elongation A5 8-10 % Hardness 91 HB physical properties Density 2,7 g/cm� good welding properties very good anticorrosion properties good anodizing properties good drilling and turning properties alloy: AlSiMgMn (former AlMgSi1) Temper: T651 stress relieved by stretching ,heat-treatable Composition %: Al 96.5, Mg > 0.64, Si > 0.7 |
There is an indepth thread on the subject here
Excellence article on Fuchs, (issue#93 pg 107) says the alloy used to make Fuchs is "AlMgSil or AA6082." AA6082 is; Al 0.9Mg 1.0Si 0.7Mn --OR-- 0.9% Mg (Magnesium) 1.0% Si (Silicon) 0.7% Mn (Maganese) 97.4% Al (Aluminum) [implied balance] Slightly different from Jacks of Nicks of Joachims factory info. For yet another data point . . . and a bit more detail; http://forums.pelicanparts.com/uploa...1147901714.jpg |
Wow,
And here I thought I was the only one who went to matweb.com for entertainment. You guys had better stop all this talk before I get too excited. What comes next is a downward spiral about the drawbacks of adding sulfur to improve machinability... :eek: Chris |
And the lug nuts while we're at it?
Sherwood |
911pcars,
You don't sound very excited... Are you patronizing us? :rolleyes: Chris |
?"You don't sound very excited... Are you patronizing us?"
Chris, Not altogether. Half mocking ourselves, half-serious in that this data is both informational and related and should be in one thread. My next question is about its half-life in anticipation of the next poster. Sherwood |
Half-life!
Now you're speaking my language. It's just the natural log of 2, divided by the effective attention decay constant! Chris |
See. I told you. Sherwood |
I'm going back to lurking...
You've only got 65 posts. Of my nearly 3,000 I must have at least 100 (or more :() where I ended up puting my shoe in my mouth! SmileWavy We all learned something. |
Steveinatlanta,
Emission wrote: Quote:
Now imagine my embarassment with less than 200 posts - I'm hoping to get the dumbest stuff out of the way early. Chris P.S. - There are quite a LARGE number of very well educated and diverse contributors on this board. Post prudently, state your opinions as such, and ask questions. You and your ball should really consider staying... C |
| All times are GMT -8. The time now is 07:13 AM. |
