mark '87 930's Avatar
o2 sensor? black smoke on heavy throttle in 4th..
i went on a little trip this weekend, and on my way up to my destination, i noticed two things:
1) the car was getting HORRIBLE gas mileage.. like 8-9 mpg on the highway whereas I used to get ~25..
2) When I hammered the gas in higher gears the car was not moving, in fact was pretty much feeling like it was stalling... then i noticed in my mirror that clouds of very black smoke were coming out the muffler
When I got up there, I disconnected my o2 sensor, and everything from there forward was fine.. i hit the throttle and she pulls like she should...
So....as some of you may have read, I've very recently replaced my headers and put on a set of GHL w/heat. In doing that, I've had to take off the o2 sensor from the stock exhaust and install in the new one. I had to heat it up red for it to even budge... did I ruin it?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 07-11-2006, 08:14 AM
I think you answered your own question. Red hot is like, what, 1400-1600 degrees F? With heat, the voltage produced by the sensor rises - you probably cooked the internal wiring, if you didn't damage the tip.
The black smoke is an indicator that you were running very rich, but you probably already knew that.
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 07-11-2006, 08:59 AM
should i also consider replacing/cleaning my spark plugs. i'm guessing they're in pretty rough shape with all that gas?
1956 Chevy 3100
Old 07-11-2006, 01:36 PM
Make Bruins Great Again
Por_sha911's Avatar
You can pull the plugs and see how they look. Chances are they are fouled and since they are cheap, I would go ahead and replace them after you get a new O2 in there.
Joe
Old 07-11-2006, 07:02 PM
