rear plate bracket
I need a rear license plate mounting bracket for my car (a '71). I can't seem to find one from our host. Will the one from 74 on work? Any ideas?
Thanks Colin
Colin '71 911T |
Anybody? I've checked Pelican, Mid-America, and Performance.
Colin '71 911T |
Back in New England!
Did you call Pelican? They have parts that aren't on the website, so you have to call them in order to purchase them.
Usually if they do not carry it, they will assist you in finding one from another maunfacturer. Good luck, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
The Stoddard website shows them for $6 each with part number 644-701-051-00. I have one on my car along with the correct factory front bracket.
If you punch that number into the Pelican part search, it shows to be a special order gasket at $19.54. I agree, call Pelican as I'm sure they can get one for you. |
