vaccum leak? *pic*
I'm trying to fix a slightly rough idle and what appears to be a rich mixture at idle. You can hear the exhaust sputter at idle. Car is also somewhat balky on shifts. Could this split hose on the back of the thottle body the possible culprit? car is a 1984 3.2 ROW. Unfortunately Pelican is out of this item and unable to source.
Old 08-31-2006, 04:47 PM
randywebb's Avatar
could be - spray kerosene or something on it while running to see
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-31-2006, 04:50 PM
take the split hose off and pinch it closed. If that fixes your idle then it could be your issue. but don't you think it would run leaner if air was sneaking by there. does idle change when you plug or unplug the o2 sensor?
Old 08-31-2006, 04:52 PM
I have yet to try the Oxygen sensor.
Old 08-31-2006, 05:26 PM
ruf-porsche's Avatar
Take the hose to Pep Girl or Manual Zone, they can probably match it up.
Old 08-31-2006, 05:32 PM
using propane/kerosine/carb clearer is difficult.
It is a difficult are to reach with the AFM and airbox in place.
Do you just flood the area with the stuff?
Old 09-01-2006, 04:27 AM
seperate the AFM from the air filter housing and run the car. then you can reach back there with the gas if you want. Don't let anything get sucked up in the AFM while your running the car without the filter
Old 09-01-2006, 05:00 AM
randywebb's Avatar
just get some fluid on there so it'll seal the leak momentarily -- you'll hear the motor improve
oughta replace that thing sooner or later anyway tho...
Old 09-01-2006, 03:26 PM
KCinBR's Avatar
I went to Autozone and purchased "feets" of each size vaccum hose and replaced all I could find. Had to purchase some of the other special type formed breather hoses. Takes a little work but worth it. Oh yeah mines an 88 3.2
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 09-01-2006, 05:09 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
did your idle improve noticably?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 09-01-2006, 06:48 PM
KCinBR's Avatar
Yes my idle improved. Also before replacing the hoses I could remove the oil tank cap and there was no change in idle, afterwards the idle would change when removing the oil cap.
KC
2005 Boxster S
Old 09-02-2006, 04:17 AM
