Typical Salesman
jeffrey2's Avatar
3.2 vs 3.0 muffler
I just bought a Carrera (3.2) muffler and have an 79 SC (3.0); is it a real trial to make it fit or should it be a simple conversion? (simple being bolt on)?
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 08-31-2006, 08:23 AM
nope its 1.250 inches longer then the SC one.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-31-2006, 08:41 AM
Typical Salesman
jeffrey2's Avatar
1.250 inches longer in what way? The "to the muffler" part is longer, the muffler is bigger, the exhaust tips are longer?
Old 08-31-2006, 08:48 AM
sorry the inlet pipes
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-31-2006, 09:31 AM
anthony's Avatar
Just curious - could a whole 3.2 exhaust system be retrofitted to a 3.0 SC motor? Would it flow any better or be worth the effort?
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 08-31-2006, 09:41 AM
yes it would work but I do not think it would flow any better
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-31-2006, 11:35 AM
DB_NC_95C2's Avatar
I will be selling a Fabspeed 'premuffler' (catalyst replacement, no catalyst capability) and a Dansk Sport Muffler (1-in-1-out) when I put SSIs on in a couple of weeks, in case you or other SC owners might want them.
If you're thinking stock 3.2 muffler (once you've made it fit) would add performance over the 3.0 muffler, I think stock = stock (i.e. if it's flow or performance you want, get away from stock).
I made the mistake doing just the cat bypass and sport muffler (not that it didn't significantly improve the engine's power and sound but I should have listened to the little voice inside that said 'you know you'll do SSIs eventually') . In hindsight I'd have done SSIs, 2-inlet muffler all at once, then I'd not have the ordeal of finding a good home for my Fabspeed/Dansk combination.
'95 Porsche 993 Carrera, DACH-X, DACH-R, PSS10,RS Speedlines,RS StrutBrace, GT3TEK 993RS Aero
'06 Mini Cooper (O.Z,MTH, Milltek, M7)
http://www.hakkinen.com/spain99-mh1st-easy.mp3
Old 08-31-2006, 12:38 PM
