drag racing the short bus
All Aluminum pressure plates. Where to find them?
What years did Porsche provide all aluminum with their clutches? Was it just '70 and '71. I'm looking for one in lieu of my pending transmission rebuild.
I know Sachs has a power clutch kit, but the flywheel, from what I understand, is not all aluminum, but rather aluminum with a steel face. Thanks for your help.
The Terror of Tiny Town |
Information Junky
I found one in my SC. ...and wasn't even expecting it.
![]() Yeah, it's an Aluminum body with a steel spring element. (aluminum- not a great spring material.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Information Junky
dd74,
I think the aluminum pressure plates must have started in '76 or '77. I know my '77 2.7L engine came with one. Don't think they were on '75 & before.
Marv Evans '69 911E |
Registered Usurper
When I bought my '82 SC I turned it over to my mechanic to go through completely.
He said "When Oy did your clutch, Oy put in a aluminium pressure plate(His British accent was bogus, the pressure plate was Sachs). Oy think you'll loyk it" I said "O.k.".
'82 SC RoW coupe |
Anyone care to guess what the face material is - it's black, but what material is it? Aluminum or steel? And can this piece work with a Sachs clutch, or will it require an OEM clutch? Thanks again.
Information Junky
ya mean this image? (Wayne is tricky with locking out those images) Steel, btw
My 72 911 had an all aluminum clutch which was original. Very light but had a copper face on the pressure plate. If this is what you're looking for.... I really don't think anyone produces this type of pressure plate any more. Good luck!
Kevin |
Information Junky
The Pelican link reads for 72-86.
I doubt there is a problem with either disk. (d/k for sure)
I mean, I'm no longer part of that 3.0 liter and larger torque-meister knuckle-dragging set.
