Ram air
why don't i see anyone cobbling up a ram air set-up on a 911. seems like an easy way to increase power. in the normal configuration the air intake is located in a hot, dead zone....seems like the wrong place to take in air. imagine a long, conical section, scoop along side the rear window....
Just add a tail to your car and you'll have a ram-air setup.
Also, do a search, this has come up several times before and had several long threads associated with it.
Here's a good thread with interesting data.
http://forums.pelicanparts.com/showthread.php?threadid=72259
hmmm. i think to be effective (to increase intake pressure) you'd need about a square ft of opening facing into the airstream piped directly into the intake. on a typical motorcycle pumping about half the volume you have about half that area
drag racing the short bus
This solution:
which results to this (look for the silver hose): seems to be the best I've seen. There's also this: ![]() which isn't very aesthetically pleasing, I'm afraid.
The Terror of Tiny Town |
Administrator
Re: Ram air
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Ram air is overrated unless you routinely drive at 100+mph. Even then, your air intake must be properly configured for the mass air flow.
Sherwood |
