Are there parts manuals available for a 1984 911 Turbo Look either factory or reprints? I saw some postings going back to 2000, but the links were no longer working.
Thanks, Mitch |
Mitch,
Did you try here? http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/originalpartspdfcatalogue/
Harry, since you're so knowledgeable and my local Porsche Parts Man is not, one more question...
Is there anyway I can get the original "build sheets" for my car? Thanks, Mitch P.S. I liked you red racer...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Mitch,
As far as I know, the window sticker will likely not be able to be replaced, however, PCNA in Georgia can sell you a Certificate of Authenticity for your VIN and give you original color and options. Do a search for Certificate of Authenticity and/or COA and you should be able to get more details. I think the fee is about 100 or 125 bucks. If you look on the underside of the hood you will see a sticker with option codes. Those can be decoded as well if you post them.
Tony G 2000 Boxster S |
Tony,
Bless you my Son... I've talked to the local Porsche dealer, I've called PNA Customer Service and have only gotten a big "no". Great information, I really appreciate it. Mitch
http://www.porsche.com/usa/accessoriesandservices/porscheservice/ownerservices/certificateofauthenticity/
here is your short cut.
I picked up a PET, parts manual, on e-bay for about $15. About the best $15 i've ever spent. Besides giving the part numbers it makes almost everything I work on make more sense.
John Birkett 2008 Cayman S, Midnight Blue Metallic 84' Factory Turbo Look M-491 (gone but not forgoten) 02' Boxster S, Seal Gray Tiptronic (gone) |
3.4 Bigger is better
Pelican carries this Porsche PDF Catalogue They are temporarily out but it is great to have. Same info as you can get online but I can never find the online site when I need it.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Michael, Thanks for your help... TonyTheTarga came through with a link to download a PDF file from Porsche of North America's web site:
http://www.porsche.com/filestore.aspx/default.pdf?pool=usa&type=download&id=1ae0ec77-7a5b-4245-9fbb-2e1a4d4e702d&lang=none&filetype=default For $90.95 you can obtain a "Certificate of Authenticity" for your car. What a great resource the Pelican Parts web site is. Thanks to all.... Mitch
