OK. after checking the fuses and relays and a thing called a DME , All seem fine....I have found that the only was I can get her to start is with starter fluid. Once I get it started she runs fine. But as soon as I turn it off. I can't get it started again without the starter fluid. Any ideas??? Thanks
Bill Greene |
Does your fuel pump run while cranking? We need more info...
Mackskibum aka Dave Austin '66 911 Work In Progress (#303734) '85 911 Carrera 06 325XI '05 Envoy XL SLT |
Just did some more digesting of your problem. You need to check your reference sensor and connection. If I remember correctly, if your refernence sensor is not sending a signal to the DME, the fuel pump will not run. Once the engine starts, the DME switches to using the TDC sensor for timing and it will still run.
If I am wrong about this, I am sure someone will correct me.
