-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Gas Filler Protective Flap...how the heck? (http://forums.pelicanparts.com/showthread.php?t=360147)
1982911SCTarga 08-03-2007 05:59 AM
Are you sure that's correct? On mine, the small flap covers the windshield washer fluid filler cap. If you turned it around, wouldn't the small flap interfere with the hinge every time you close the fuel door?
Steve, why not go flapless and save the weight? :)
Brian
bkreigsr 08-03-2007 06:12 AM
Originally Posted by Formerly Steve Wilkinson (Post 3408283)
We do understand that the gas filler "protective flaps" are useless in any case, right? Period-correct I can understand. Wanting to protect my paint job from spilled gas by using a little rubber handkerchief I can't. I never even bother to unroll mine when I gas up, and it's new and fits perfectly.
not too sure about it being useless here in Jersey, where we are prohibited by law from touching the pumps or hoses. Most attendants use the fender as a heel rest for the nozzle, and the flap prevents chips, especially when they decide to rest a spell and lean on the the nozzle while you take a wiz.
granted, the law is seldom enforced, but they always get first crack at the insertion.
jmohn 08-03-2007 08:33 AM
Brian
You're absolutely right, the small flap covers the fuel filler door CATCH not HINGE. I don't know why I wrote hinge earlier.
Jerry M
'78 SC
rusnak 08-03-2007 10:25 AM
no, the flaps lay flat over the fender when folded out. The small flap folds out toward the windshield, and lays flat on top of the fender. The large flap folds out and down. It protects the fender against the metal fuel filler, as stated by Mo. To work well, the canvas/ rubber flaps need to be soft and pliable. When they become hard and curled, they won't fold out and lay flat - and won't work to protect the paint. I have a nice custom paint color, so I appreciate having the fuel flaps.
Wil Ferch 08-03-2007 12:09 PM
Ahem...maybe small flap toward the latch, right... ??? Small flap "hinge point" faces front of car?
Yeah...the flap protects more against scratches than is does to protect from fuel staining, as formerly Steve suggests.
charleskieffner 08-05-2007 02:34 PM
too many moving parts for some i guess!
snbush67 08-07-2007 04:32 PM
er..towards the hinge..latch...washer cover.......does anyone have a picture?
Is'nt gold a soft metal? SmileWavy
Maybe its hardened gold plating.
Wangan 12-19-2023 10:44 PM
Hi all,
Having the same issue with fitting the fuel flap to my car.
I know the large flap opens toward the bottom of the car. Not sure which direction the small flap should be opening towards. Should the small flap be on the left, or right? Opening toward the hinge, or the catch (windscreen direction).
There is a small hole in the flap too. Not sure what this is for.
I've seen so many cars with it fitted both ways, so not sure what is correct.
Wangan 12-19-2023 10:46 PM
Also, should the flap be pushed down toward the bottom of the fuel filler neck, or kept right as the top, just below the opening.
Wangan 12-19-2023 11:26 PM
http://forums.pelicanparts.com/uploa...1703060676.jpg
http://forums.pelicanparts.com/uploa...1703060863.jpg
If these photos which is correct?
shadowjack1 12-20-2023 05:54 AM
I put mine like in the second picture. The hole is there for draining the gas.
Wangan 12-20-2023 12:53 PM
That is what I see the most, but makes the least sense. Why have the flap opening up against the fuel filler lid itself. I have no idea what's the correct way
pmax 12-21-2023 03:50 PM
Sounds like another one of those, which way questions e.g. engine mount ?
canamfan 12-21-2023 08:25 PM
I would think the 2nd picture is more correct to prevent fuel splash onto the soft plastic of the washer fluid cap, it might deteriorate the cap prematurely?
Bill Douglas 12-21-2023 11:09 PM
I've had the 911 for 28 years and never used it. Darn, I've been missing out.
When I replaced the fender I put a new one on just to be correct. The hole was a bit small but I just forced it on.
pmax 12-23-2023 08:07 PM
http://forums.pelicanparts.com/uploa...1703394466.jpg
Here ya go.
Gas drips and all caught by the flap instead of the original paint.
Bill Douglas 12-23-2023 10:24 PM
Oh... I'll try that during the week. Thanks, and nice yellow!
