Sump plate sealing
At some point in its life, the sealing surface for my sump plate was damaged.
It leaks. Anyone have a recommendation to seal this up better, it gets messy. ![]()
'82 911 SC IG: @rywats |
it uses 2 gaskets--did you have those on it?Gasket screen another gasket and the strainer plate...You can always use some kind of sealant..Loctite 574 or other...
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Yes, I used 2. You can see the marks at 9 oclock on the photo. Oddly enough, they look like grinder marks.
Do you combine the 574 and oem type gasket material?
yes you`ll be fine with the gasket and 574 or even Curil T2 would work
Yup ,looks like grinder mark Ivan
It's a 914 ...
I’d try Curil T first. So much easier to clean up.
Hope it’s not stating the blindingly obvious but also check to ensure the sump plate/cover is flat. They distort easily with too much tightening and will cause leaks. I guess you could fill the grind marks with E-metal, epoxy putty or similar and file flat. It should do the job and isn’t under any real pressure.
This is a good video to review: https://www.youtube.com/watch?v=t-IkUVUBals
73 914-6 GT tribute, 3.2L SS twin plug 23 911 w/aero kit 07 GT3 RS Pumpkin |
