Bill Verburg's Avatar
While you have the m/c out it might be helpful in the future to measure the m/c
Here are the dimensions that are needed
Bill Verburg
Old 09-28-2007, 06:20 AM
Bill, I'll do that tonite.
I am trying to identify that Corrado unit as well.
regards
andy
Old 09-28-2007, 06:54 AM
regards
andy
Thanks,
ps I doubt that the Corrado will work
Bill Verburg
Old 09-28-2007, 07:02 AM
Bill, dimensions as promised:
Diameter D 41.5 mm
L1 152 mm
L 170 mm
SM Centers 86mm
Mount bolt centers 60 mm
Mount bolt holes 9.2 mm
No chance of this fitting my car unless I mount it upside down with the reservoir inlets at the bottom which is not really the best option. I'm onto AP racing as well for a special .
thanks
andy
Old 09-29-2007, 12:23 AM
Thanks!, those #s are for the 23? Do you still have the stock 19?
Bill Verburg
Old 09-29-2007, 05:02 AM
Brake Master Cylinder
Sorry guys I don't have the original anymore.
The Corrado unit does fit. The stroke is the same as the ATE 23 mm unit. The original pushrod will also work. The clearance issues are largely solved. I have to make some shouldered nuts for it or fit longer pedal box bolts and the brake pedal stop needs adjusting. The proof will be in the final testing but its looking good .
See pictures below of trial fit.
Old 09-30-2007, 12:42 AM
1972_911T's Avatar
Hi hassad did you ever get this corrado mc working? im strugling to find the 23mm here in the UK but I presume the corrado one will be easily available from euro parts etc.
Thanks Steve
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 02-04-2008, 10:05 AM
Carrerax's Avatar
Any updates to this corrado master cyl?
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 03-26-2011, 04:46 AM
Cornpanzer's Avatar
Would be interested in hearing how it worked as well.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 04-13-2011, 07:05 PM
palle7688's Avatar
Any news about the corrado mc?
What model year is it from? Partnumber would be great.
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 02-02-2012, 07:30 AM
See my post #14.
A search in ebay shows descriptions with similar specs: E.g.
VW BRAKE MASTER CYLINDER Golf Cabrio Passat Jetta Corrado 16v 357611019B (NEW) | eBay
These are one of my long term projects as well. However, after I suggested that alternate MC, Hassad did PM me that it worked.
Sherwood
Old 02-02-2012, 10:58 AM
Tomeric914 (Tom) on 914World.com provides an excellent write-up on the 22.2mm VW-Corrado MC installation.
914World.com - The largest online 914 community!
Sherwood
Old 12-29-2020, 02:13 PM
