-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Masking Fuchs for painting centers - share your masking tips (http://forums.pelicanparts.com/showthread.php?t=379092)
JackMan 11-25-2007 05:27 AM
Gents
I've searched the BBS, done my research and now I'm going to refinish my track wheels. I'm repainting the inside of the wheel black using rattle can Wurth. The lips I'll polish with PS21 stuff I bought from PP.
My question is, Can someone please share with me the materials and technique for properly masking the aluminum, unpainted wheel lips?
Any tips that someone can share with me?
Pictures would be appreciated.
Wellborn
Oh Haha 11-25-2007 05:30 AM
Black electrical tape works great for making curves. Also, fine line masking tape is useful.
JackMan 11-25-2007 05:51 AM
Where do you get fine line masking tape?
jerhic 11-25-2007 05:58 AM
use electrical tape! makes sure the tape is not cold.
Gogar 11-25-2007 06:04 AM
instead of trying for an hour to make nice lines with electric tape (which is a fine idea), you could use wide blue painter's tape and "over-tape" the lip, taping into the black, then cut the line you want between the lip/black with a razor blade.
Oh Haha 11-25-2007 06:10 AM
Nice tip, Gogar.
Fine line tape can be found at hardware stores. What I meant was to use thin width tape to get the fine lines, then use wider tape to cover the other areas. When I did my Fuchs a few years ago, I did it this way and they turned out very nice. My wife painted the center caps while I did the wheels.
Jeff Jagusch 11-25-2007 06:14 AM
masking Fuchs
You might try an auto paint supply store for masking tape.
I have some blue plastic tape similar to electrical tape but it's 1/4" wide, and very flexible.
It is widely used in the industry , and leaves a sharp edge unlike plain masking tape.
good luck
joefrantz 11-25-2007 06:41 AM
I used eighth inch striping tape from Pep Boys, black electrical tape, and blue masking tape. Sand lightly with 600 after masking, then black self etch primer and Wurth satin. I also taprd the lug nuts and set them in place to prevent paint from getting on the mating surfaces.
Good Luck
Joe
http://forums.pelicanparts.com/uploa...1196004671.jpg
http://forums.pelicanparts.com/uploa...1196004748.jpg
http://forums.pelicanparts.com/uploa...1196004896.jpg
http://forums.pelicanparts.com/uploa...1196005064.jpg
http://forums.pelicanparts.com/uploa...1196005135.jpg
jorian 11-25-2007 07:21 AM
Just did a rough job on my winter Fuchs. Used electrical tape to train around the edge and then taped newspaper around the balance of the wheel. If you cut large arcs out of the newspaper it is very easy to mask. Took about 10 mins per wheel.
JackMan 11-25-2007 10:44 AM
Gogar, excellent tip. Thanks to all for pixs, etc.
Anymore?
wj
