" roller rockers"
Why doesn't someone manufacture roller rocker arms for Porsche?? Wayne have you ever contacted comp cams and asked them. It would seem like almost free horsepower and an easy way to do it.
Keith Epperly
87 slant nose turbo look Carrera cabriolet
Old 12-14-2009, 01:14 PM
I would rather be driving
jpnovak's Avatar
Generally there is physically not enough room within the cam tower to implement roller rockers. A rede$$$gn of the cam tower would be required.
There are some stories in the archives with more information.
Old 12-14-2009, 01:22 PM
why WOULD THEY REQUIRE MOORE ROOM, THE ROLLER ENDS WOULD BE SLIGHTLY LAGER AND A ROLLER BEARING FULCRUM SHOULD BE THE SAME SIZE. ADJUSTMENT WOULD BE IDENTICAL WITH A SWIVEL FOOT.
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 12-14-2009, 01:39 PM
3 restos WIP = psycho
kenikh's Avatar
I talked this over a while ago with several of the engineering eggheads who frequent this site - these are the guys that make their livings on cams and engine building - all have tried and given up. The reasons are:
1. Width of the rocker journal prevents a strong enough setup with the full width roller, obtaining the proper ratio and clearing the valve covers - consensus is new cam towers would be needed.
2. Cam geometry totally changes - replacing the radius tip with a roller tip reduces the radius and slows down the camshaft action; you'd would need to calculate conversions for proven profiles to new geometry in going from sled rocker to roller rocker.
3. Normal chill cast camshafts wont work with a steel roller follower, so you would need some blanks made from 8620 steel. You'd need new billets to make usable cams.
By the time you get done with all of that, you might as well make new heads with a better valve angle, too.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-14-2009, 02:36 PM
dshepp806's Avatar
Originally Posted by kenikh View Post
i talked this over a while ago with several of the engineering eggheads who frequent this site - these are the guys that make their livings on cams and engine building - all have tried and given up. The reasons are:
whew!!!!!!!! (meaning good info...)
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-14-2009, 03:23 PM
kenikh's Avatar
Credit goes to Camgrinder, Jamie and Burn Bros for most of this info.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-14-2009, 03:29 PM
You'd need new camshaft housings as well to accomodate different rockers and geometry.
Might as well make it a 4-valve engine, too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-14-2009, 04:37 PM
AutoBahned
RWebb's Avatar
...then you'd need to flow water thru it to cool things off
say, while we're at it, why don't we see if we can eliminate the parts count and make it easier to assemble...
ooops! somebody already did that
Old 12-14-2009, 04:42 PM
Max Sluiter
Flieger's Avatar
He had that covered
Old 12-14-2009, 04:48 PM
Almost Banned Once
sc_rufctr's Avatar
It can be done with the stock cam towers and covers... The geometry and cams can all be worked out.
Back in the 70s these were made for Australian produced 6 cylinder engine with push rod vales.
Surely in 2009 this cam be done for the Porsche flat 6.
As you all should know it's been done for air cooled VWs for a long time.
I'm bit surprised that some professionals have given up on this idea.
- Peter
Old 12-14-2009, 04:54 PM
Max Sluiter
Flieger's Avatar
But if we had roller rockers, what would happen to all the oil threads and arguements? If we do not need Zinc and Phosphorous, then anything goes.
Old 12-14-2009, 04:58 PM
Max Sluiter
Flieger's Avatar
I would also be interested to see any photos you might have of this setup.
Old 12-14-2009, 05:07 PM
I'm in.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-14-2009, 05:25 PM
Not necessarily. Somewhere around here, I have a prototype air-cooled 911 4-valve head,...(I didn't make it).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Last edited by Steve@Rennsport; 12-15-2009 at 12:45 AM.. Reason: Proper Punctuation
Old 12-14-2009, 08:42 PM
Czar of C.R.A.P.
dfink's Avatar
Keith Epperly
I would guess it has something to do with money.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 12-14-2009, 09:28 PM
AutoBahned
RWebb's Avatar
Originally Posted by Steve@Rennsport View Post
Not necessarily. Somewhere around here. I have a prototype air-cooled 911 4-valve head,...(I didn't make it).
that's interesting!
I always thought that P AG flowed water thru the heads to cool them.
of course, maybe it was a rejected prototype...
- do you know the history of it?
Old 12-14-2009, 10:03 PM
that's interesting!
PAG certainly DID water-cool them for best efficiency,......
The one I have was not made at the factory.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-15-2009, 12:46 AM
gtc gtc is offline
abides.
gtc's Avatar
Has anyone tried putting a ceramic pad on the rocker, similar to the lifters that Schubeck racing made (sold by LN and Jake Raby)?
Graham
1984 Carrera Targa
Old 12-15-2009, 11:43 AM
