Somatic Negative Optimist
Gunter's Avatar
Question Colors for CIS connectors WUR, AAR, CSV, etc.
I searched for a while but................
CSV is blue
ASC is green
WUR is ?
AAR is ?
Frequency Valve = ?
Thx.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-16-2008, 11:27 AM
Scott R's Avatar
freq valve is white, wur and aar are black, at least on mine.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-16-2008, 11:42 AM
Brad w's Avatar
Thanks Gunter and Scott
this is what I am doing tonight. Checking all the plug locations are right.
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 04-16-2008, 12:12 PM
Brad w's Avatar
What is the name of each part?
CSV =
ASC =
WUR =
AAR =
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 04-16-2008, 12:47 PM
Slumlord
Porsche_monkey's Avatar
I read the question and immediately thought. 'Oh, Gunther will answer this one...". Oops, I guess even he was stumped.
WUR=warm up regulator
AAR= air advance regulator?
Old 04-16-2008, 03:08 PM
Designer King
Paulporsche's Avatar
Warm Up Regulator
Cold Start Valve
Auxiliary Air Regulator
Airflow Sensor Contact
All are CIS components
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-16-2008, 03:29 PM
Color Coding......
CSV is blue
ASC is green
WUR is ?
AAR is ?
Frequency Valve = ?
Thx.
Gunter,
The color of the sockets & plugs for CIS components like WUR, AAR, CSV, Air sensor switch, etc. were not the same from harness to harness. While most of the CSV I've seen were BLUE, some WUR and AAR were in gray or black. I believe the color coding of the wires were consistently maintained but not the color of the sockets/plugs for CIS parts. A post recently showed a green color for the air sensor switch. And found a brown color too. So we can not use the color as a standard guide for the connectors unlike the wiring harness.
Tony
Old 04-16-2008, 03:33 PM
Gunter's Avatar
Originally Posted by boyt911sc View Post
Gunter,
Tony
I would think that Porsche used the color code to prevent accidental connections to the wrong plug and I find it hard to believe that they would confuse things by mixing connector-colors.
The differences may be due to an after-market replacement of the connectors because these Bosch parts are pretty common on other vehicles.
I am sure that a newer SC harness would show the correct colors.
These 2 seem to be fairly consistent:
CSV = blue
ASC = green
That leaves us with black, brown and gray.
WUR = gray ??
AAR = black ??
FV = brown ??
Of course, the length of some wires determines the location but it is possible to switch between CSV - ASC or FV - CSV or even AAR - WUR ??
If anyone has a newer type SC harness, please, check the colors.
Old 04-17-2008, 08:57 AM
Brad w's Avatar
Gunter I just put a new harness on my car and the only color connectors were blue and green. This was the one for the sixteen pin to the ALT, Starter, Blower Motor, and such.
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 04-17-2008, 09:30 AM
Gunter's Avatar
O.K.
I clearly remember colors for the WUR, AAR and FV on a '82 CIS, just forgot which colors went where.
Hmm...........it's a mystery.
Old 04-17-2008, 09:59 AM
