Electrical help!
Hello do everybody.
Im finishing my project and ran into a problem when trying do get spark. It is a 72, 911 2.4 with webers, it seems do have somekind of sensor instead of contacts. There is a ignition module on the side (big alloy box 4 wires going in) There is Black, going to ignition sensor in the distributor. Blue/Yellow going to Coil + Ground Red going? Is the red wire electrical source? on the scheme it goes do fuse number 8 and seems do be + Also sensor in the distributor has black and red wires going in , as i understood Black is signal , and red is + ? Thank you. harri |
Sports Purpose 911 Driver
pictures are really required with this type of problem. it would seem to me that the red wire would be 12v switched power (ignition on power).
but please post pictures.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Mr. Cramer, as ever, is more prepared than I.
Prepared is as prepared does Jimmy! Semper Fi!
LOL! good stuff John, I miss out little debates over beers. Keep an eye on NYC for me.
Thank you, next problem
when i connected red wire to 12+ ignition on, the CDI started to make noise. Is that normal? And also any ideas about the sensor instead of points in my distributor. Pics will be coming in evening. Looking other topics, i found out that it is a Petronix ignition. |
Max Sluiter
CDI boxes will make a high pitched noise when functioning properly.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Got the spark last night.
I did not have any 12+ do red wire. If everything goes allright i will be starting the car on friday. Will give some pictures also latter. Thank you all |
