3.2L Carrera fuel line leak
As far as I can tell I do not have any fuel line leaks, but there are a number of lines and connections in the system. If I were to replace a line from a preventative standpoint which one should it be ? If I wanted to "keep an eye on it" where are the most common places that leaks occur that I should be looking at ? I am concerned about it but wanted to focus on the most likely to leak areas first.
Thanks, Mike
1985 Carrera 1995 325is 2000 Grand Cherokee |
MBruns for President
it would be tough to spot as part of the line goes back behind the intake AND fuel evaporates quickly - lots of threads on it.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I replaced all mine in Dec. 07. I had the motor out for a clutch job. I used fuel injection hose from a local parts house, I did not buy the fabricated fuel lines. the factory crimps can be easily removed and the metal line itself can be reused with no problem. I also used clamps that are for "fuel injection" not the regular hose clamps.
KC 88 Guards Red Targa (sadly sold ![]() 2005 Boxster S 1st Porsche 73 914 (long gone) |
You should replace the all .........is the answer to your question. ![]()
Check out pages 101 & 102 of the 8th edition of my book...
Keep the Shiny Side UP! Pete Z. |
don't make me repeat myself
If/when you have the motor out be sure to inspect the little hook shaped hose on the driver side/back side of the motor which has a connector on it. This little hose will set you back $165 at least. I tried to have one made, but the bend is too severe and the hose gets pinched.
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Hey KC. Thought you developed a little stutter there for a moment moment moment...happy Friday.
Jim '88 Targa |
The one in worst shape on my car was the tank to fuel pump hose.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
i had leaks in the lines around the fuel pump. you can remove the stone guard thing and take a look.
