carwash's Avatar
Body Leading on a '68 912 Chassis - Factory?
So, in the process of getting the many layers of paint off this chassis, i have gotten into a couple corners in the rear that have a very large amount of leading bodywork on them. In particular in the corners of the rear valance where the cover latch lives and at the top of the channel where the engine covers sits in...
Take a look at these pics. I didn't realize they used lead at all from the factory, and maybe they didn't. Maybe this is all old school body work, etc... can anyone clarify this either way? And if there was lead used, is this an abnormal amount or is this common? I'm not going to put lead back in, but i'm trying to decided if want to pull it all out, that stuff is heavy as hell, lol.
1968 912 - widebody - 3.2 - 915 - endless build
1980 911 - targa - barnfind nightmare - gone
1985 911 - targa - barnfind nightmare - gone
2017 991 - C4S - summer daily - for sale
IG - therealcarwash
Old 11-12-2016, 07:25 AM
djpateman's Avatar
If the factory put it there, I don't think you should remove it.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-12-2016, 08:23 AM
carwash's Avatar
well the factory put a lot of things there that i'm removing...
IG - therealcarwash
Old 11-12-2016, 06:41 PM
gestalt1's Avatar
Unless there is rust around those areas that needs repair, leave it. Worked perfectly for 40+ years.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 11-13-2016, 07:59 AM
carwash's Avatar
I went into those corners aggressively with a heavy wire wheel and tore the hell out of it, lol
Odd that there is not a drop of lead anywhere else on the chassis besides in the rear on the deck lid crossmember and upper corners...
IG - therealcarwash
Old 11-13-2016, 01:49 PM
thorloki
Factory used lead as final body fairing. I would not remove unless you are handy with hammer & dolly or planning on body filler. Lead craftsman were real craftsman in those days.
1977_911 to 1990_964 wide body conversion
Old 11-13-2016, 03:37 PM
RETIRED
Joe Bob's Avatar
My 65 "C" had leaded doors.......so up to 70-71 MY IIRC.
2012 ML350 3.0 Turbo Diesel
Old 11-13-2016, 03:40 PM
carwash's Avatar
yeah, i wish i hadn't dug into it as far as i did... but i didn't know it was lead.... the only spot that's going to require some edge reforming is one of the top edges of the rear deck lid channel. I'm amazed that they from that hard edge with lead.
IG - therealcarwash
Old 11-13-2016, 07:44 PM
1QuickS's Avatar
Lead also used between rear of rocker panels & rear quarter panels, rear quarter panel to panel across rear of engine bay and at base of windshield to front cowling piece. Lead used anywhere a large panel is connected to an adjoining panel where the joint would be visible: those seams were filled with lead.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-14-2016, 07:33 AM
Paper Member
Watch the "Made by Hand" youtube videos. I think they do lead work in those.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 11-14-2016, 07:48 AM
carwash's Avatar
What year did they stop using lead?
IG - therealcarwash
Old 11-14-2016, 08:09 AM
