red sc
78 SC egr system
I am having a hard time finding the complete egr system that the PO removed over 12 years ago. I can't find any listings new or old anywhere. Even the muffler with the fitting for the egr filter is not available. Do I just drill a hole in the muffler that I have and weld a fitting on it? I found a used parts dealer that will sell me the egr, bracket, two pipes and egr filter for $600 bucks . I think this is my only option
Old 02-20-2009, 10:23 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
i think i have most all what your looking for as i swapped a 78 3.0 into a 75 carrera and the 75 year was a non catalist car didnt need any of the egr stuff i may have the spider and the pump and brackets im not sure what else you need. if you could get a picture of whats needed i may have some of it.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-20-2009, 10:29 PM
red sc
Here is a list of the parts I need
part item #
EGR filter 21
pipe 28
gaskets (2) 29
bracket 35
mount 36
EGR 30
Old 02-21-2009, 01:14 PM
red sc
I forgot to add one more item.
pipe item # 32
Old 02-21-2009, 01:15 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Why do you want this?
Do you have that type of exhaust manifolds?
My 78 did not have an EGR system.
Old 02-21-2009, 06:23 PM
UNDER CONSTRUCTION!
i agree with rattlsnak
your car shouldnt of had thermo reactors, when you said egr i assumed you ment air injection, what i ahve is a smog pump brackets and i think a rail or spider that injects air into your heads.
you really dont want to stay with this system as those reactors if you have them are sheer death to your motor.
ed
Old 02-21-2009, 07:19 PM
red sc
EGR (exhaust gas recirculation ) system is required to pass smog in California for 1978 and 1979 . I have the air injection system already. The previous owner removed the egr system and threw it away. The car has not been driven since 1995. The smog test were easier then. A lot of cheating was going on then too.
Old 02-21-2009, 07:44 PM
UNDER CONSTRUCTION!
got it EGR
but the parts shown above are for a thermo reactor type exhust. you may indeed need a EGR system but just double check which system you are running before you buy parts. i think you can change this type of system out for normal exchangers and a cat and be way better off. that is what we do and alaska fallows cali. guidlines.
sorry to lead you astray on the parts i thought i had,
ed
Old 02-21-2009, 09:45 PM
rattlsnak's Avatar
Is it failing the visual inspection or something? And as Ed asked, do you have the correct exhaust and muffler? I have never seen a 78 with an EGR system is why I ask, but of course I dont live in CA either.
Old 02-22-2009, 09:22 AM
beancounter
jwasbury's Avatar
Not sure if its the same part, but I have the EGR filter and some plumbing that I just pulled off my '79 turbo. Yours for cost of shipping if it will help you get passed CA emissions testing.
Old 02-22-2009, 09:43 AM
red sc
The smog check involves both visual and functual tests.The way to test the EGR system is to apply vacuum to the valve which should cause the engine rpm to drop. This would indicate a properly operating system.
Old 02-22-2009, 09:57 AM
rattlsnak's Avatar
Dont know much about Ca. emissions but are you telling me they actually hook up a vacuum pump and test the egr system? And I cant believe anybody would not miss it on a visual especially if you have the air injection system working.
Old 02-22-2009, 11:01 AM
red sc
They have to actually see the valve and connect the hand vacuum pump to it. I know it tough out here . The state will send undercover agents with cars with missing emision components to see if they can catch the smog technician off guard.
Old 02-22-2009, 11:52 AM
red sc
I checked my emission application guide and a 79 turbo has the same egr parts. Yes I am interested . I make it worth your time.
Old 02-22-2009, 12:03 PM
beancounter
jwasbury's Avatar
Take a look at this thread:
http://forums.pelicanparts.com/showthread.php?t=457301
Scroll down to post #8 and there is a photo of the exhaust system I pulled off. You can see the EGR filter. I also have the hard line that goes from that filter, up through the tin to the EGR valve. I do not have the EGR valve, and the end of the piping that goes to the valve has been crimped off. These are the only parts left of my EGR system. Send me a PM if you want this stuff.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-22-2009, 12:25 PM
red sc
Thanks for the help and offers guys. I found out yesterday when I visited a local Porsche shop that the system that I displayed is from a 1977 and is different. The 79 turbo system is different too. ( thanks anyway jwasbury ). I found an egr on ebay for 39 bucks. The guy at the Porsche shop says he can find the rest of the parts that I need. Thanks again guys.
Old 02-24-2009, 07:56 AM
