Ignition buzzer switch
Hi ,
I couldn't. figure how to install the Buzzer switch (#2) which is located at the end of the ignition switch under the steering column.
Any help will be greatly appreciated.
Old 03-11-2009, 05:59 PM
group911@aol.co's Avatar
If I remember correctly, they are screwed on.
Thanks,
Bob
group911@aol.com
Old 03-11-2009, 07:23 PM
If it's screwed on there should be a screw hole on it. I've pulled mine off long ago as the buzz was quite annoying! But I cannot remember if I just unplugged it or pulled the entire switch off, just recall no screw involved.
'87 3.2 Targa
Old 03-11-2009, 09:28 PM
Thanks Guys,
Unfortunately, I can see a hole in the switch (Item 2) but no where to screw it to on the ignition switch... unless it is screwed directly to the car body.
Regards
Old 03-12-2009, 10:02 AM
Recall it may just snap in the recess.
'87 3.2 Targa
Old 03-12-2009, 06:17 PM
